Old 03-25-2021, 07:58 PM   #1
Bo White
Bo White's Avatar
Stock bottom end to 416
I swapped my valvetrain and heads over from my old build to the new one so this is 376 vs 416.
Kudos to Scott Culbert at Gen 3 Performance and Dyno for getting it straightened out. There it is in black and white(and red and green) difference between stock bottom end and 416 bottom end. Blake Winslett gave me a hand on swapping the LSA injectors out to the FIC 72lb ones since I knew it was gonna be thirsty(which it was on E85, they are at 95% DIC). Thanx to Terry Wilkes for assembling my shortblock at Wilkes Performance. Also Jason Mangum at Texas Speed and Performance on the parts selection on valvetrain and PRC 260s. Cam is 243/255 in both.
Red is 93 pump stock bottom end
Blue is 93 pump 416
Green is E85 416
Totalled:
Old 03-25-2021, 09:25 PM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
those are solid numbers.
what rpm will you be shifting at?
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 03-26-2021, 05:40 AM   #3
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Great results!
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 03-26-2021, 06:38 AM   #4
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Damn 518 on stock bottom end is solid
Bigdumogre is offline   Reply With Quote
Old 03-29-2021, 04:22 PM   #5
Bo White
Bo White's Avatar
Been driving it around some Friday and today. I'm loving the fatter torque curve. I did tighten my 6000 stall up when I swapped engines because I knew the added torque would make the converter stall higher and I was right. I went back to my first 8" stall that I ran before. It stalls out at 5500-5600 now. It should loosen up a touch once I get some more miles on it. You can see the difference in stalls in the dyno sheet. I'm making almost exactly 100hp/60tq more now than the last time I ran this stall. 437/389 was what I made stock bottom end, stock manifold, stock ported heads and BTR3 cam.
Totalled:
Old 03-29-2021, 04:32 PM   #6
Bo White
Bo White's Avatar
If it were still a manual I figure it would be 580/510 based on my previous testing between manual and th400.
Totalled:
Old 03-29-2021, 10:03 PM   #7
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
Very nice Bo!
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 03-29-2021, 10:49 PM   #8
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Crazy how little was gained bumping up to a stroker. Ive always thought this was the case, but you proved it. Thanks for posting Bo. As always, your car is badass!
gunchamp is offline   Reply With Quote
Old 03-29-2021, 11:04 PM   #9
Bo White
Bo White's Avatar
Peak HP wise correct. Through the curve is huge. I'm over 40tq in some spots.
Totalled:
Old 03-29-2021, 11:11 PM   #10
Bo White
Bo White's Avatar
Clarkstar had the same findings. He has a manual.
https://www.camaro5.com/forums/showthread.php?t=557005
Totalled:
Old 03-30-2021, 06:16 AM   #11
gunchamp
gunchamp's Avatar
Yup, noticed that. The torque bump is very nice
Old 03-30-2021, 08:46 AM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Great job Bo!! Badass as always!!
Old 04-03-2021, 03:03 AM   #13
Bo White
Bo White's Avatar
People ask how I like the 416 compared to the 376 since all I changed was the bottom end. I tell them it's like giving someone a spin in the car and you can tell the added weight is there. The stroker feels like I had someone in the car with me the whole time with the previous build and they finally got out lol.
Totalled:
Old 04-04-2021, 04:35 PM   #14
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
The added torque is always nice to have. I always thought the 416 needs a large cross section area intake runner, larger valve and a large volume plenum intake to make lots of power up top. Kinda like a LS7
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
