06-20-2017, 04:45 PM | #1 |
Drives: 2012 Camaro RS convertible Join Date: May 2017
Electric exhaust cutouts
Has anyone installed the electrical exhaust cutouts on a camaro? I know it would sound cool, but I'm curious about performance or any issues?
06-20-2017, 05:15 PM | #2 |
Drives: 2017 ZL1 A10 Join Date: Sep 2014
I want to know about the best, cheapest ones out there.
Current: 2017 ZL1 A10 previous: 2019 1SS A10 previous: '14 L99, CAI intake, vmax ported tb, e85 kit, stage 2 cnc heads, speed engineering long tubes, custom high flows, resonated x pipe, muffler delete, qtp cut outs, gpi ss3 vvt Cam, zl1 pump and injectors, fti triple disc, mayhem motorsports trans cooler and tune, ngk spark plugs +red msd wires, 3.91 gears. Past: '12 LFX, full bolt ons + E85, 302hp/267tq |
06-20-2017, 05:42 PM | #3 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
QTP is probably the cheapest you're gonna get. As with anything mechanical, the motors in them will probably go out after a few years. Everyone seems to love them. You can get the higher end ones from Noweeds which are probably better quality. Only heard good things about both. A google search will net you some results for threads on here if you include Camaro5 after the search.
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
06-20-2017, 05:58 PM | #4 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Spike III Build 2011 IBM 1SS/RS [COTW 6/25/12]
QTP cut outs.
06-20-2017, 06:42 PM | #5 |
Is that after the h pipe location? I want something like right after the long tubes lol. Looks great though nice quality
06-20-2017, 07:51 PM | #6 |
Drives: 2010 2SS/RS Join Date: May 2010
You can't tell that is before any H or X pipe???? Those look mounted perfectly to me!
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
06-20-2017, 08:01 PM | #7 |
If you look at his second picture, the H pipe is at the very top of the screen lol his are mounted right after the headers. Beautiful set up, I want to do this as well.
06-20-2017, 08:35 PM | #8 |
2011 2SS m6 LS3
Drives: 2011 camaro 2ss Ls3 Join Date: Jun 2017
Where did you put the switch on the inside of the car
06-20-2017, 08:43 PM | #9 |
Yea I really couldn't tell if that was right before or right after /shrug
06-20-2017, 08:49 PM | #10 |
Anyway that's the exact set up i was looking to do, bet it sounds ridiculous.
06-20-2017, 08:49 PM | #11 |
Drives: 2011 2SS/RS Join Date: May 2014
This may sound like a dumb question but how does this affect the exhaust note of an aftermarket exhaust?
"Scarlett" the Black Widow
BTR Stage 4 Cam, FTI 3600 Stall Converter, GM 3.91 Gears, GPI Intake Mod V2, CAI Cold Air Intake, SLP 25% Underdrive Pulley, LS3 Conversion, PRC Ported/Polished Heads, Stainless Power Long Tubes w/off-road pipes, Borla Atak Cat-Back Exhaust, Tru Cool 40K 482rwhp/425rwtq, Built and tuned by Champion Motors |
06-20-2017, 08:55 PM | #12 |
Drives: 2015 Summit White SS Join Date: Aug 2014
I have no weeds on my car. They are the highest quality cutout available. QTP is a good budget choice, but I wasn't ready to have a gear go out on mine and have them stuck open. The no weeds are also a diverter instead of a cutout so instead of creating a large exhaust leak they close off the rest of the exhaust and open the exhaust up completely.
Full Bolt-Ons w/ Nightfury Cam (471rwhp)
06-20-2017, 08:59 PM | #13 | |
By having the cutouts placed right behind the headers after the cats, you flip the switch and it's like you just took the the exhaust off because the sound is exiting there instead of at the back of the car. Most of the time cutouts have turn down pipes as well which bounce the sound off of the ground making it seem louder due to the echo and you'll feel the vibrations more. Watch this to tell the difference in sound that it makes: Please note that your airbags will not deploy with this mod. Nick's car is gutted and makes the vibration way worse because he has no sound deadening.
06-20-2017, 09:11 PM | #14 | |
