06-08-2017, 09:25 PM | #1 |
Drives: 2015 1LE Join Date: Mar 2016
Racing Harness
Does anyone have it without the roll cage just for looks? if so where can I get it and how much and please show pics
I would really like to add them just for looks. |
06-08-2017, 09:29 PM | #2 |
Drives: Camaro Justice Join Date: Jun 2007
Without a harness bar or roll cage there is no safe way to mount the shoulder straps. They should have a down angle of 5* and no more than 10*. Mounted to the floor or other such methods can cause severe spinal injuries.
06-08-2017, 10:23 PM | #3 |
It's just for looks I will not be racing I don't wear seats belts as it stands now so it will be for looks lol
06-09-2017, 02:30 PM | #4 |
Drives: 2010 CAMARO SS Join Date: Apr 2010
here is your best bet,,, this is what I have ,,, quality of this outstanding !
http://www.bkauto.com/R_1150_Harness...r_p/r-1150.htm |
06-09-2017, 02:35 PM | #5 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
Seat belts are a standard part of my routine. They are buckled for me and all passengers in every vehicle I drive---before the vehicle is put in gear. It's a personal choice, but years of flying military aircraft ingrained it into my psyche! There are too many uncontrollable factors out there on the highways; I want things I can control working for me.
06-09-2017, 02:44 PM | #6 |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
if you don't wear the seatbelt, just buy this
OR JUST DUCT TAPE TO BACK OF SEAT! |
06-09-2017, 07:10 PM | #7 | |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
06-09-2017, 09:21 PM | #8 |
Use the BK and harness to hold you in place to drive faster. Wear the OEM belt over or under it for safety. In a severe impact, I have seen this very stout, very well made BK bend with a large driver and seat mounted on the factory tracks.
06-09-2017, 10:00 PM | #9 |
Drives: 2015 Summit White SS Join Date: Aug 2014
I use a schroth rallye 3 asm. It bolts into the rear seatbelt bolt and is at a safe degree behind the seat. A harness bar with a 4 point is likely more safe however I can take a picture later of my 3 point so you can see how it works.
Full Bolt-Ons w/ Nightfury Cam (471rwhp)
06-09-2017, 10:31 PM | #10 | |
Drives: 2011 2SS/RS Join Date: May 2014
"Scarlett" the Black Widow
BTR Stage 4 Cam, FTI 3600 Stall Converter, GM 3.91 Gears, GPI Intake Mod V2, CAI Cold Air Intake, SLP 25% Underdrive Pulley, LS3 Conversion, PRC Ported/Polished Heads, Stainless Power Long Tubes w/off-road pipes, Borla Atak Cat-Back Exhaust, Tru Cool 40K 482rwhp/425rwtq, Built and tuned by Champion Motors |
06-09-2017, 10:34 PM | #11 | |
FIA run with a 40 degree down angle. The new batch of Miatas being raced have the 40 degree down angle. The company that builds the cars had major issues with the belt manufactures. The belt manufacturers insist the down angle be no more than 10 degrees and prefer 5 degrees. The Scroth belt you are using has an even higher down angle. I have read through their materials and don't understand how they come to the conclussion the belt design is appropriate. SCCA, NASA, NASCAR, IMSA, Trans Am all adhere to the 50m to 10 degree range for shoulder strap down angle. I have not tested belts and may be completely wrong in my thinking, but these are my thoughts. The reason for the down angle specification is to avoid crushing the spine during impact. As the body moves forward against the should straps, a relatively straight (no more than 10 degrees of down angle) should strap has relatively straight forces being transferred to the torso. If the belt is fastened to a location as low as the seat bottom, as the torso is thrown forward, the shoulder straps pull down creating the forces required to crush the spine. My number one priority as a car builder is not to build a fast car. Priority #1 is driver safety. All decisions are based on driver safety first last and always. With that as the #1 priority, I am going with the most conservative installation of a harness bar, cage and harness. We go no lower than 7.5 degrees. If i am wrong and 40 degrees is safe, I haven't hurt anyone. If I go with 40 degrees or more and some one gets hurt... In sshort, I am not saying your belt installation is not safe. I am saying I wouldn't use one or install one. I also know that opinions are like axx holes and everyone has one. Mine is no better or worse than most. |
06-09-2017, 10:40 PM | #12 |
Look at the design of the bars. Count the supports. What direction are the supports facing? Is there any triangulation? Think about where the load is when a car suddenly decelerates and the bar must hold the weight of the driver and possibly the seat. Which bar will distribute the load is the safest way?
06-09-2017, 10:42 PM | #13 | |
06-09-2017, 10:45 PM | #14 |
In my option, and we already discussed what those are worth including mine, the BK is a clearly superior design and well worth the extra cost.
