10-07-2017, 10:12 AM | #29 |
Drives: 2015 Camaro ZL1 Join Date: Sep 2017
So after taking my car to 3 different dealerships, they have all came to different conclusions. One tells me to replace my TPS and re-calibrate (no clue how to do that), another tells me that their is a possibility that the MAF and MAP sensors are failing,(not the truth because I have replaced both already). The last one who is the first that I took it to wouldn't work on it, just recommended replacing the entire intake system. I'm at the point now where I think I should just put a stock intake back on it to see if it remedies the issue. Really miss getting sideways from 1st to 3rd.
10-07-2017, 10:16 AM | #30 | |
ZL1 Pilot
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs |
10-07-2017, 10:21 AM | #31 |
10-07-2017, 10:32 AM | #32 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Can you contact he original owner and find out exactly what has been done i.e tuned, or if an when the SC was replaced. If it was there are a bunch of sensor connectors down the left fuel rail that should be checked that are associated with theses codes. I would take that Cold Air Intake tube off and inspect the throttle body. Push the TB open and inspect both sides for being clean.
10-07-2017, 11:30 AM | #33 |
ZL1 Pilot
This place has great reviews on the LS1 forum. Maybe they can help?
https://www.trifectaperformance.com/...age/index.html https://www.facebook.com/TRIFECTAPerformanceInc/
10-07-2017, 12:26 PM | #34 | |
10-07-2017, 12:30 PM | #35 | |
10-07-2017, 01:06 PM | #36 |
ZL1 Pilot
I would also re seat the two ignition/fuel injection harnesses as well. Just make sure everything is connected and the locks click
10-07-2017, 01:23 PM | #37 |
Don't shoot brake cleaner into the butterfly, put it on a rag and hand wipe the underside which is probably the dirtiest, then some carb cleaner at the pivot points. If you have that much carbon check the CAI tube for clean. Also recheck the filter, you said you cleaned it, you realize they must be reoiled not just airblown. Easier to just get a replacement, but if in doubt just do a quickie with it off, yes the MAF will be screwed up, but does it change the WOT issue.
10-07-2017, 03:29 PM | #38 | |
10-07-2017, 05:00 PM | #39 |
I have a RotoFab, if there is a dry filter in here and it's supposed to be oiled, will it throw these codes???
10-07-2017, 05:24 PM | #40 |
Drives: 2015 Summit White SS Join Date: Aug 2014
It's a bit of a drive but Tom at Wongs Performance in Vancouver could probably help you out. He has tons of experience on ls cars.
Full Bolt-Ons w/ Nightfury Cam (471rwhp)
10-07-2017, 05:26 PM | #41 |
ZL1 Pilot
No. Go to Autozone or equivalent and get a can of Mass Airflow cleaner. Clean that thing and report back with findings.
10-07-2017, 08:08 PM | #42 |
Drives: 2010 1LT SIM A6, 2005 GTO TR A4 Join Date: Jul 2009
I had that issue on my 05 GTO when I first had it. It was throwing a code for TPS. I disconnected the battery, took the throttle body off, cleaned it real well, reset the code and it never came back.
