Old 10-12-2010, 11:50 PM   #1
VaderCamaro2010
VaderCamaro2010's Avatar
Drives: 2010 Camaro 2SS/RS M6
Crank HP vs RWHP
So my stock LS3 SS camaro was putting down about 345 rwhp (thats about what they average) with 426 hp at the crank. With a few bolt on mods it made 410 rwhp on the dyno....a gain of 65 hp. So does that mean its making 490 hp at the crank? I know crank hp doesn't really matter but just curious.
"Don't make me destroy you."
VaderCamaro2010 is offline   Reply With Quote
Old 10-13-2010, 12:01 AM   #2
derklug
derklug's Avatar
Drives: 12 Boss 302
Using simple math, it should be 506 at the crank, but that assumes that the loss through the powertrain remains at the same percentage.
The biggest mistakes in life come when you know exactly what you are doing.
derklug is offline   Reply With Quote
Old 10-13-2010, 01:04 AM   #3
JUISSD
JUISSD's Avatar
Drives: 2010 White/IOM 2SS/RS M6
Yep. Your loss was 19%. However there are a lot of variables to consider. Did you use the same dyno? Were the weather conditions the same? Dynos are primarily tuning tools and the numbers can vary.
2010 White/IOM Camaro 2SS/RS M6
JUISSD is offline   Reply With Quote
Old 10-13-2010, 01:35 AM   #4
Sax1031
Drives: 2000 Mustang GT
Dynos are a tuning tool and nothing else.
Sax1031 is offline   Reply With Quote
Old 10-13-2010, 01:37 AM   #5
Entaille
Drives: 2018 Camaro 2SS
word. people get way too fixated on numbers.
Entaille is offline   Reply With Quote
Old 10-13-2010, 01:59 AM   #6
mikeSS
mikeSS's Avatar
Drives: 2015 c7
ya i always tell my friends and people what the crank HP is ... only people that know cars will understand RWHP... its goos to have a idea what crank HP is
mikeSS is offline   Reply With Quote
Old 10-13-2010, 02:11 AM   #7
GQ4Life
Drives: 2010 Camaro SS LS3
I tell everyone engine HP.. if they car guy I will say wHP too..
Standard is 15% drive train loss on manual ..
So take 410wHP divided by .85 is 482HP at engine
Stock 430HP times .85 equals 365wHP what a lot of LS3's dyno
Ur dyno prob reads low no biggy its just a tool to give estimate to compare & tune
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 10-13-2010, 06:42 AM   #8
clg_98ta
clg_98ta's Avatar
True dat. Your 65 hp gain at the wheels with 'simple bolt-ons' is a very good gain if you are talking just intake/exhaust mods.
Perhaps the first dyno was low for some reason - with 15% losses, a stock LS3 should put down 362 hp at the wheels. Are these corrected numbers?
Black 2SS ordered 1/4/2010, received 2/19/2010
clg_98ta is offline   Reply With Quote
Old 10-13-2010, 07:06 AM   #9
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Most shops will say there is a 15% loss for the Manual/LS3 camaro .. that being said, 415 at the wheels would put you around 488 at the crank ... (415 / .85 )
That being said, is that 415 at the wheels on a dyno jet .. and as stated above, was your stock and then modded numbers on the same dyno and in similar conditions?
thanks,
Crowley
Crowley is offline   Reply With Quote
Old 10-13-2010, 09:32 AM   #10
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
Originally Posted by JUISSD View Post
Yep. However there are a lot of variables to consider. Did you use the same dyno? Were the weather conditions the same? Dynos are primarily tuning tools and the numbers can vary.
I have found out the hard way on this. I did some addons to my car, I do have a baseline prior to those, but I went to a different dyno, and the numbers off the second one were so inflated that it was just stupid.
Basicly I baselined at 370rwhp, and 365 max torque. Second dyno with new addons, 441rwhp and 460 max torque. Sure the numbers look great, but it's not a true representation of what i really have.
I should have been around the 395 to 405rwhp and just a shade over that for torque.
Baseline mods
Cold Air Inductions intake
Borla S-Type cat back
Addons
Dynatech Headers
Dynatech High flow cats
Custom Tune
So my next course of action is to take it back to my orginal dyno I used and see what the true gains are.
armysig is offline   Reply With Quote
Old 10-13-2010, 06:29 PM   #11
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Your first run seemed a little low. I think the LS3 Camaro's are usually roughly 20 hp more than that
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-13-2010, 07:27 PM   #12
GQ4Life
Most LS3's seem to be 365 to 375
Old 10-13-2010, 07:35 PM   #13
oldfriend
Drives: Fiat 500 E
Wink 2SS
YEAH IT CAN BE SIMPLE MATH, BUT YOU CANT GO BY % , LETS SAY SOMEONE DROP IN A 1000 HP ENGINE AND ALL OVER SUDENT YOU LOOSE 19% OF THAT IT WILL KNOW LOOSE 190HP TO THE DRIVE/POWERTRAIN , SORRY BUT THIS DOES NOT MAKE SENSE AT ALL!!!!:bo w:
oldfriend is offline   Reply With Quote
Old 10-13-2010, 07:47 PM   #14
DGthe3
Moderator.ca
DGthe3's Avatar
Please turn caps lock off before writing a post.
Drive train losses are more complex than a simple percentage but the loss at the interface of a pair of gears is based on percentage of input power, not an absolute value.
Review: 473 rwhp Mike Norris Motorsports cam ducatisl Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 10-26-2010 05:12 PM
rwhp Verse Crank HP BoostedX2 5th Gen Camaro SS LS LT General Discussions 11 09-22-2010 01:37 PM
My goal of 650-700 rwhp Dreamer2430 5th Gen Camaro SS LS LT General Discussions 2 03-09-2010 08:17 PM
