Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment
Old 12-12-2021, 06:11 AM   #1
FrankieBee
Drives: 2015 Commemorative Edition
L99/LS3 Bare Block
I have a L99/LS3 block with stock crankshaft, stock pistons (1 rod is bent so has to be replaced), intake manifold. Came off a 2011 Camaro.
Was going to use it on my 2015 but decided to go a different route.
Accepting offers . Will take pictures later today. SOLD
Procharger D1SC - JDP ZR1 Cam - FAST LSX 102 intake, ARH , 729.7 RWHP 698 RWTQ
FrankieBee is offline   Reply With Quote
Old 12-20-2021, 08:05 PM   #2
FrankieBee
Old 01-05-2022, 01:28 PM   #3
TrickRacin
TrickRacin's Avatar
Drives: 2011 2SS/RS
Is it still available, and are you willing to ship it?
TrickRacin is offline   Reply With Quote
Old 01-05-2022, 01:31 PM   #4
FrankieBee
PM sent
Old 01-07-2022, 01:55 PM   #5
FrankieBee
Main caps.
Old 01-07-2022, 01:57 PM   #6
FrankieBee
Piston #7 bent
Old 01-07-2022, 01:58 PM   #7
FrankieBee
Bent rod
Old 01-12-2022, 03:56 PM   #8
Scott S
Scott S
Drives: 2011 Camaro 2SS
L99/LS3
That block is an L99 block as it has the oil holes in the valley on top of the towers. Easy to block of though...
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
Scott S is offline   Reply With Quote
Old 01-12-2022, 04:13 PM   #9
FrankieBee
Yep that is why description has it as L99/LS3.
Old 01-12-2022, 08:57 PM   #10
Pkeen
Pkeen's Avatar
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche
My 2010 ss m6 ls3 block has those same holes !
Pkeen is offline   Reply With Quote
Old 01-12-2022, 10:48 PM   #11
FrankieBee
