dave@hennessey
Old 08-02-2021, 10:15 AM   #1
FrankieBee
Drives: 2015 Commemorative Edition
Slow Start- Starter Heat Soak Issues
After reading lots of threads about this issue I decided to add some ground straps first instead of replacing the starter.
I have a LS3, cammed, headers and Procharger that has been having the slow start issues for a while.
I first went to the trunk and added a ground strap from the negative battery cable to the body.
I then added another ground strap from the back of the starter to the body.
And the third ground strap from the transmission bell housing to the body.
I just did this over the weekend and after using the car all weekend long not 1 slow start yet!!!
Procharger D1SC - JDP ZR1 Cam - FAST LSX 102 intake, ARH , 729.7 RWHP 698 RWTQ
FrankieBee is offline   Reply With Quote
Old 08-02-2021, 10:59 AM   #2
Leo72793
Drives: 2011 2SS/RS
I added a engine to chassis ground (direct to frame) and havent had this issue. The starter grounds to the engine. Even if the starter is grounded to the chasses, the rest still needs to be enhanced. I went Drivers side head to frame.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
