Vararam
Old 12-10-2020, 09:06 AM   #547
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by NYCss View Post
What is the minimum fuel system needed to run an E60mix with a Whipple on a stock L99? Will the gains if any worth the investment? I see you did this type of work on a 6th gen with good results.
It really depends on the pulley or boost level
With a blower on pump gas you need a ZL-1 fuel pump and either our FSCM or tuning of yours along with a JMS fuel pump voltage booster for anything more than 6 psi boost.
Add in E85 and you need 30% for fuel supply so larger injectors, ID1050x and the fuel system might not keep up for more than about E40
So when we do Flex fuel conversions on Blown Gen 5 we go with Fore innovations return system, and ID1050x or ID1300x depending on power goal.
If this does not answer your question clearly don't hesitate to call me.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 12-11-2020, 08:31 AM   #548
FrankieBee
Drives: 2015 Commemorative Edition
Originally Posted by JANNETTYRACING View Post
use a 1/4 mile calculator
600 rwhp will go 131 mph
Using that calculator what vehicle weight are you using?
Procharger D1SC - JDP ZR1 Cam - FAST LSX 102 intake, ARH , 729.7 RWHP 698 RWTQ
FrankieBee is offline   Reply With Quote
Old 12-11-2020, 08:48 AM   #549
JANNETTYRACING
Same one I have been using for 40 years proven right every time, the Moroso Power-speed calculator.
Then doing the math for driveline loss.
4000 lb.
Ted.
Old 12-11-2020, 09:06 AM   #550
FrankieBee
4000 lb.
Ted.
So the HP number they provide is rear wheel HP?
Old 12-11-2020, 09:26 AM   #551
JANNETTYRACING
Most all On line calculators are Crank HP which you shown above are the same values I came up with.
Multiply by either .85 for Manual cars .80 for Auto cars to convert to RWHP.
Bottom line car is not showing anywhere near Dyno numbers on the track.
Again I would like to reinforce it is easy to produce a Glory number on the dyno, but not so easy to produce a real number that is repeatable on the track.
Everything I do on my dyno goes to the track and backs up the numbers with in 2% or less.
Ted.
Old 12-11-2020, 09:52 AM   #552
FrankieBee
Ted.
Not all online calculators use crank HP.
Old 12-11-2020, 10:04 AM   #553
JANNETTYRACING
Did I say All?
Old 12-11-2020, 10:30 AM   #554
FrankieBee
Did I say All?
No but you didn’t say that some use crank HP.
Old 12-11-2020, 10:41 AM   #555
JANNETTYRACING
So your just looking to argue or be critical of info I am providing
Old 12-11-2020, 10:45 AM   #556
FrankieBee
Not argue just stating that there are other variables that come into play that can affect 1/4 mile times. Would you agree with that?
Old 12-11-2020, 10:56 AM   #557
JANNETTYRACING
That is a different subject.
I clearly stated that MOST ALL online calculators I have seen are Crank HP.
You came back with NOT ALL.
I never said ALL.
Now on to your new question.
ET is a wild variable heavily effected by Driver and chassis set up.
MPH is consistent regardless of ET, providing shift points are correctly selected.
MPH over 1/4 mile is the best Dyno.
These calculators are accurate, it is simple MATH that can not be disputed.
X force accelerates X Mass at X Rate over X distance taking in to account an average frontal area.
Ted.
Old 12-11-2020, 11:17 AM   #558
FrankieBee
I never said ALL.
Ted.
So a car that ran xx 1/4 mile at yy speed at end of track using that calculator you can determine the crank/rear wheel horsepower ?
Old 12-11-2020, 11:25 AM   #559
JANNETTYRACING
Absolutely, like I said the Track is the best dyno.
Old 12-11-2020, 11:42 AM   #560
FrankieBee
