12-10-2020, 09:06 AM | #547 | |
With a blower on pump gas you need a ZL-1 fuel pump and either our FSCM or tuning of yours along with a JMS fuel pump voltage booster for anything more than 6 psi boost. Add in E85 and you need 30% for fuel supply so larger injectors, ID1050x and the fuel system might not keep up for more than about E40 So when we do Flex fuel conversions on Blown Gen 5 we go with Fore innovations return system, and ID1050x or ID1300x depending on power goal. If this does not answer your question clearly don't hesitate to call me. Ted.
www.jannettyracing.com
12-11-2020, 08:31 AM | #548 |
Drives: 2015 Commemorative Edition Join Date: Jul 2013
Using that calculator what vehicle weight are you using?
Procharger D1SC - JDP ZR1 Cam - FAST LSX 102 intake, ARH , 729.7 RWHP 698 RWTQ |
12-11-2020, 08:48 AM | #549 |
Same one I have been using for 40 years proven right every time, the Moroso Power-speed calculator.
Then doing the math for driveline loss. 4000 lb. Ted.
12-11-2020, 09:06 AM | #550 | |
So the HP number they provide is rear wheel HP? Sent from my iPhone using Tapatalk
12-11-2020, 09:26 AM | #551 | |
Multiply by either .85 for Manual cars .80 for Auto cars to convert to RWHP. Bottom line car is not showing anywhere near Dyno numbers on the track. Again I would like to reinforce it is easy to produce a Glory number on the dyno, but not so easy to produce a real number that is repeatable on the track. Everything I do on my dyno goes to the track and backs up the numbers with in 2% or less. Ted.
12-11-2020, 09:52 AM | #552 | |
Not all online calculators use crank HP. Sent from my iPhone using Tapatalk
12-11-2020, 10:04 AM | #553 |
Did I say All?
12-11-2020, 10:30 AM | #554 |
No but you didnt say that some use crank HP. Sent from my iPhone using Tapatalk
12-11-2020, 10:41 AM | #555 |
So your just looking to argue or be critical of info I am providing
12-11-2020, 10:45 AM | #556 | |
Not argue just stating that there are other variables that come into play that can affect 1/4 mile times. Would you agree with that? Sent from my iPhone using Tapatalk
12-11-2020, 10:56 AM | #557 | |
I clearly stated that MOST ALL online calculators I have seen are Crank HP. You came back with NOT ALL. I never said ALL. Now on to your new question. ET is a wild variable heavily effected by Driver and chassis set up. MPH is consistent regardless of ET, providing shift points are correctly selected. MPH over 1/4 mile is the best Dyno. These calculators are accurate, it is simple MATH that can not be disputed. X force accelerates X Mass at X Rate over X distance taking in to account an average frontal area. Ted.
12-11-2020, 11:17 AM | #558 | |
So a car that ran xx 1/4 mile at yy speed at end of track using that calculator you can determine the crank/rear wheel horsepower ? Sent from my iPhone using Tapatalk
12-11-2020, 11:25 AM | #559 |
Absolutely, like I said the Track is the best dyno.
12-11-2020, 11:42 AM | #560 |
