04-25-2021, 06:54 PM | #113 |
Daaaammmmnnnn man!! Now we're getting somewhere.. lol. Looking really nice my friend!!! Can't wait to see how she does for you.
04-25-2021, 08:04 PM | #114 |
Thanks brother! Im getting very excited. Only have the boost a pump to finish and im done. Ill get it done this week and on to jannetty remote tuning!
04-25-2021, 08:10 PM | #115 |
Got the FPCM from jannetty installed today. Its in the pass side rear side wall. You have to remove the rear seats to get the plastic off to access this guy. Fairly easy
04-25-2021, 08:11 PM | #116 |
04-25-2021, 08:13 PM | #117 |
Use a drill bit stop and left roughly an 1/8th inch of bit showing. Just enough to punch through. Used electric metal sheers from harbor freight and it worked great
uploading pictures
04-25-2021, 08:15 PM | #118 |
And new pump installed along with the fuel pump ring removal tool. Listen, I know you can use a punch or chisel and a hammer. Have done it myself in the past. My ring was completely and utterly stuck. This tool was like $25 on amazon and made the job extremely easy. 2' long breaker bar and it was a breeze
04-25-2021, 08:54 PM | #119 |
Drives: Camaro Join Date: Oct 2018
I heard the fuel pump tool wasn’t needed but damn did it make the job easier for me.
04-25-2021, 09:13 PM | #120 |
Same here!!
04-26-2021, 05:39 AM | #121 |
Looking good gunchamp! I swapped my fuel pump out a few weeks back and bought that tool prior to doing the swap. I was really surprised at how tight that ring was and sure glad I had the tool!
04-26-2021, 07:36 AM | #122 |
Same, glad I jumped on the tool. Would have been a pain in the rear with how tight the ring was. Also, to anyone wondering, I had a 1/4 tank of fuel and that was just about too much. The fuel was almost level with the opening when I removed the pump assembly.
04-26-2021, 10:21 AM | #123 |
I never realized the GPI top end was LS7 style. That's gonna make some good power.
FYI, when I ran the V3si head unit, I used a 95mm pulley and it made 10.5psi on my combo. stock heads, 2inch headers and 226/236 525/525 110. I'm guessing here, but with your ls7 style top end and that 105mm pulley, you probably wont see 10psi. Do you have any other pulleys available?
2011 Camaro SS---SOLD
04-26-2021, 11:20 AM | #124 | |
04-26-2021, 11:57 AM | #125 | |
AJ mentioned he was working on a larger lower pulley. If that is ready, it would be a great option. The bigger the pulleys, the more belt wrap.
04-26-2021, 03:54 PM | #126 | |
