Old 10-19-2023, 07:12 PM   #1
Callaway24
Drives: 2016 Chevrolet Camaro ss
ProCharger intercooler air to water switch
Recently changed my ProCharger stage 2 intercooler to a air to water one. That’s all I have done. The problem now is that the car will not run. Idles terrible and can’t give it any throttle or it dies. If I remove the intake hose before the maf sensor it runs great. As soon as I move the hose back to the intake tube blowing air from the pc it kills the motor. I replaced the maf sensor and that did nothing. My question is, does it need to be retuned because the new intercooler is so much smaller?
Callaway24 is offline   Reply With Quote
Old 10-20-2023, 05:04 AM   #2
cheeze9878
cheeze9878's Avatar
Drives: 17 camaro ss
Is there an air flow problem? Why does the car die? is it choking out or just a quick shut off? I can't see why changing the cooling would make a difference if the car runs or not, I could see it changing only how long it would take to heat up and maybe over heat though.
Just my two cents since no one else chimed in yet
cheeze9878 is offline   Reply With Quote
intercooler, pro charger, procharger
