Old 03-25-2024, 01:25 PM   #1
Rnovrit
Rnovrit's Avatar
Drives: 2018 NFG ZL1-1LE
Clutch pedal sensor switch and pig tail?
Does anyone who where to find a source or the part number(s) for the actual plug connector for the clutch pedal position switch? I am looking to make a small plug and play extension for the switch. I can purchase another switch and cut it up to make one end but I still need the body harness connector end. I prefer not to cut the factory harness for what I am doing.
Thanks!
Rnovrit is offline   Reply With Quote
Old 03-25-2024, 02:01 PM   #2
ctrlz
can you post pictures? We do have some Connector Gurus on here!
I suspect the best option may be to find another (used) GM product that has the correct connector on ebay.
Old 03-25-2024, 03:06 PM   #3
Rnovrit
Rnovrit's Avatar
Thanks. I ordered a replacement switch. The switch turns out to be a commonly used GM brake pedal switch on many models. I ordered what I think is a replacement harness extension. I kept at my Google searching after I posted. I think with enough bits and pieces from here and there I can make this work.
