11-02-2022, 01:50 PM | #1 |
Drives: Zl1 Join Date: Oct 2022
ZL1 - 1LE front lip
Has anyone put the 1le front lip on a normal zl1? If so which one did you go with?
11-02-2022, 02:25 PM | #2 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
I have and I just put an oem zle front splitter on. I just had my paint guy paint match it to my mosaic black car color. I was debating on getting a cf version but since I track the car, it would get beat up pdq so I just went with oem.
11-02-2022, 03:23 PM | #3 |
Lots of people have done this, myself included.
Wildhammer has everything you need. https://wildhammermotorsports.com/body-parts-6/ |
11-03-2022, 10:24 AM | #4 |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
I just ordered all of the parts to convert to the 1LE aero. It's much cheaper if you order through sites like gmpartsdirect. Saved over $500 doing so instead of going with the wildhammer kit.
https://www.camaro6.com/forums/showp...95&postcount=3 You will have to buy the ZLE grille to mount the ZLE front lip, FYI. |
11-03-2022, 10:54 AM | #5 | |
Drives: E92 BMW M3 Join Date: Oct 2012
I will do the same as you did. Did you find the lip in stock? I looked yesterday and it was backordered.
J-Rod Built and Matt@FSP Tuned |
11-03-2022, 11:13 AM | #6 | |
Front lip (84335736) was only 21.63 in shipping at gmpartsnow - significantly cheaper than anywhere else. Ordered everything else at gmpartsdirect, shipping was like $80. |
11-06-2022, 08:06 PM | #7 |
USN CPO
Drives: 2021 Camaro ZL1, 2017 Camaro 2SS Join Date: Feb 2017
Check out this thread. Two members have done it, I am sure there is more.
https://www.camaro6.com/forums/showthread.php?t=590173 |
zl1 1le |
