04-19-2012, 10:32 PM | #1 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Warm air out of vents
This is my first 5th gen Camaro and I normally leave the vent on while driving. I've noticed that even set on cold, that fairly warm air comes through. It was 69 degrees this evening and warm air was still coming out. Is this normal? No other car Ive owned has done this. I'm wondering if it has something to do with heat from the supercharger.
04-19-2012, 10:42 PM | #2 |
Drives: 2014 Stingray Z51 Join Date: Oct 2011
Same here man
"What a coincidence, Drake returns and brings
brand new ZL1's with him...." - CAM....ZL1 |
04-19-2012, 11:14 PM | #3 |
Petro-sexual
That air goes through the heater core/ evaporator box, doesn't it, so since I believe I heard it's easier to heat air than cool it, I believe the heat is more dominant temperature. I don't understand what thd supercharger has anything to do with it... It's on it's own dedicated cooling circuit which I doubt goes anywhere near the climate control box. I don't havd a diagram, but I can see them interlacing ghe two systems when thry want the coolest, densist aid for the motor.
JMO
04-20-2012, 03:52 AM | #4 |
Drives: 2012 ZL1, 00016 Join Date: Jan 2012
Mine does the same thing. Also, when you are choosing a differen mode on the traction control. Where is this displayed? I can't seem to see it anywhere
04-20-2012, 04:15 AM | #5 |
HT5 COTW 9/3/2012
press the recycle air button and you'll be fine.
04-20-2012, 06:17 AM | #6 |
Drives: 2013 ZL1 Join Date: Sep 2011
I noticed that one zl1 owner said this car produces a lot of heat...........basically heated up his garage when he was done driving
04-20-2012, 06:57 AM | #7 |
Drives: 04 Silverado Join Date: Jun 2010
all cars do this...
04-20-2012, 08:05 AM | #8 |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
Supercharged engines create more heat that's why they had to put the extractors in the hood. You can see the heat coming out them if look closely.
04-20-2012, 08:07 AM | #9 |
My 2010 V6 does the same thing.
Check out my Camaro http://www.camaro5.com/forums/showthread.php?t=84133
04-20-2012, 08:09 AM | #10 |
Drives: 2018 GT350 Join Date: Nov 2011
My SS will even raise the temperature of the garage substantially after its shut off after a trip.
Additionally, yes, with the HVAC on "cold" the air coming from the vent is always warm. And no, its not normal. Every other car I've ever had has no problem with producing cool ambient air. But oh well, if thats the biggest problem with the car, I'll consider myself lucky and be happy lol
Off to the Dark Side
04-20-2012, 09:13 AM | #11 |
Drives: 2012 Camaro ZL-1 SIM Join Date: Sep 2008
This is normal. Set the AC to use the "recycle" air setting and this will stop.
04-20-2012, 09:22 AM | #12 |
Drives: 2012 45th Anniversary 2SS LS3 Join Date: Feb 2012
Right side of dash display.
04-20-2012, 09:45 AM | #13 |
Thanks everyone. I figured it was normal for this car and maybe increased due to the extra heat from the supercharger. I normally use outside air, but will switch it to recycle and see if that helps a bit.
04-20-2012, 09:53 AM | #14 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
A lot of it is just from the sun heating up the dash and everything under it. The interior of a car gets very hot out in the sun. Plus the heater core in there. Most cars I've owned the vent air is a bit warmer than ambient, including my SS.
Clicking the recirc on will kick on the A/C. If you do that regularly just make sure to go to straight vent and highish fan for the last minute or so of running. This will help dry out the evap core and prevent mold/funky smells. Shutting a car off with the A/C still on can leave it wet back there. |
