Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic modifications (exterior and interior)
BeckyD @ James Martin Chevy
Old 04-19-2024, 04:19 PM   #1
democidist
Drives: 2017 Chevy Camaro 1SS
Interior Door Panel Help
So, when I bought the car used the dealer did a good job of disguising that the door panel was peeling itself off due to part of it where the fastener secures to was broken. That weak point gradually makes more of the panel peel off (not completely). Has anyone else experienced something similar? I got a used non-broken door panel to replace it and all new OEM fasteners, but haven't put them on yet. Has anyone used stronger non-OEM fasteners to help prevent this or was it a fluke that I shouldn't be worried about?
democidist is offline   Reply With Quote
Old 04-19-2024, 07:41 PM   #2
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
This tends to happen when the door panel is pulled off to install something, say, aftermarket speakers, or when the mirror or the door lock needs to be fixed. If you install a door panel using new OEM fasteners and then never remove it (or pop it very carefully), you should be good. My door panels were never removed and they are still as good as new, no rattles, no gaps, no loose clips after 6+ years.
Also, in my experience non-OEM plastic fasteners are typically weaker (and cheaper to remain competitive), so I'd stick with OEM in this case.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 04-20-2024, 05:39 AM   #3
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
If you already have OEM fasteners, stick with them. As Arpad stated, they’re almost always better quality than aftermarket.
Chutzpah is offline   Reply With Quote
