TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Texas
Old 01-28-2016, 10:21 AM   #1
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
Texas State Inspection - Not Ready
I just took my 2010 SS in for inspection. There were three sensors; 02, heat 02 and Evap that showed not ready. The build and dyno tune on the car is almost four years old and has been without issues. The car has passed inspection every year with this same tune and build. These same three sensors have all showed ready in the past.
I put a new Delco battery in the car this past November and a catch can on which are the only changes to the setup. It's not a daily driver and only driven once about every two weeks locally when weather permitting. I've read up on several of these same issues in other threads and I've completed a couple of GM drive cycles but still showing not ready.
Any advice?
gnturboray is offline   Reply With Quote
Old 01-28-2016, 11:17 AM   #2
jrod_z28
jrod_z28's Avatar
Drives: 2012 VR Camaro ZL1
might be a weak battery. http://repairpal.com/Drive-Cycle-Issues
jrod_z28 is offline   Reply With Quote
Old 01-28-2016, 11:56 AM   #3
gnturboray
gnturboray's Avatar
Originally Posted by jrod_z28 View Post
I aware of the GM drive cycles and the battery keeps full charge.
Old 01-28-2016, 12:20 PM   #4
BillGalina
BillGalina's Avatar
Drives: 2014 Camaro 2SS/RS Crystal Red Tint
you changed the battery everything needs to reset .you will need to drive more to make this happen
Mods: V Max TB/ American Thunder Catback/ Granatelli Wires/ CAI/Catch Can,Stainless Power Headers/JRE Tune
BillGalina is offline   Reply With Quote
Old 01-28-2016, 04:41 PM   #5
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
Correct. Same thing happened to me.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 01-28-2016, 04:57 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
Ditto -- I changed battery, had to wait about 2 weeks before all systems reset -- EVAP is the hardest one period!
You can have only 1 system not ready BTW...
-Don
747 RWHP 794 RWTQ
Old 01-29-2016, 12:32 AM   #7
busaboy
busaboy's Avatar
Drives: Black RS/SS M6
I had a similar problem last year after tuning. My car had 2 I/Ms that would not pass after multiple fuel fills and several hundred miles. I was able to run the Evap test using a Tech 2 and that was enough to get me through inspection.
busaboy is offline   Reply With Quote
Old 01-29-2016, 06:21 AM   #8
DFWHD
Drives: 45th Anniversary Convertible
This happened to me last March with my 2012 when I disconnected the battery to install my CAI. The shop had me pick the car up and I did a quick fill up and 100 mile joy ride up to Oklahoma and it fixed it for me. Got the car inspected an hour later with no issues.
DFWHD is offline   Reply With Quote
Old 02-03-2016, 09:14 AM   #9
gnturboray
gnturboray's Avatar
The evap finally set but the heated O2 and the O2 still haven't set
Old 02-04-2016, 10:45 AM   #10
TXM62SS
TXM62SS's Avatar
Keep putting some miles on it brother
3.91 1LE Gears, MGW
Tuned by Pat G
Old 03-21-2016, 05:54 PM   #11
hammdo
hammdo's Avatar
What tech 2 settings did you choose to run the evap test? I'm about to run Chevrolet Passanger LS3 automatic... Did you use something else?
-Don
747 RWHP 794 RWTQ
Old 03-27-2016, 11:13 AM   #12
hammdo
hammdo's Avatar
BTW, heated 02 runs after the car sits all night (cold start) and should set within a couple of minutes... Don't leave the key on when you turn the ignition on (not started) as it heats the O2 and you then have to let the car sit for 10 minutes (assuming the car has not started)...
-Don
747 RWHP 794 RWTQ
