07-10-2010, 10:31 PM | #1 |
ADM TRANS COOLER - YES!
Got my ADM Trans Cooler installed today... Quick and painless... And running 40-50 degrees cooler easily now. Awesome! Cant wait for the track on Friday! Mwa-hahahaha...
Any one else have this installed yet? What kind of temp changes are you seeing?
07-11-2010, 12:23 AM | #2 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
I can appreciate lower temps but what good does it do your tranny fluid to run at 140 instead of 180? If we were tracking our cars, i'd see the need but for a everyday car or even a drag stip car, is it really needed?
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
07-11-2010, 06:10 AM | #3 |
Drives: Anything I want Join Date: Oct 2008
Most are seeing well over 200 degrees.
The factory cooler is built into the Radiator,Heat is transfered from the radiator to the trans fluid causing the trans temps to be at or above the engine temps.We have eliminated the fluid running through radiator and directed it directly to our new cooler that is mounted in front of the a/c condenser...first in line to get cool. Most of our testing was done in the 100+ degree heat |
07-11-2010, 06:36 AM | #4 |
Anyone with mods to their car, or a stall converter should install a trans cooler. They're too easy to install, for the amount of wear and heat problems they save you from having with your auto trans.
07-11-2010, 07:56 AM | #5 | |
Drives: Wagon Queen Family Truckster Join Date: Oct 2009
At the track a nice even temp will help perhaps with consistency, but don't think there will any reduction in ET from a trans cooler. |
07-11-2010, 08:04 AM | #6 | |
Drives: Wild Cherry Join Date: Nov 2008
had it done about 3 weeks ago and now it runs less than 180 all the time.....
2010 RJT 2SS/RS L99 CAMARO ARH 1 7/8" LT HEADERS W/ HF CATS MAGNAFLOW 3" COMP EXHAUST ADM PERFORMANCE CAI ADM PERFORMANCE CUSTOM TUNE ADM PERFORMANCE PORTED THROTTLE BODY ADM PERFORMANCE TRANS COOLER 3.45 GEARS BMR TRAILING ARMS |
07-11-2010, 09:48 AM | #7 |
Drives: 2010 Camaro SS Join Date: May 2010
I live in PA and its hot here, very hot
My trans runs at 190 MAX which is pefect, running a trans at 140 to 150 in not good. Now with a verter in the car and over 220 temps then YES a trans cooler is a must. I will see how mine runs once I add the Pro-torque 2800 to my car then make a decision on a trans cooler.. Your kit looks very nice
SOLD
2010 Camaro 1SS/A6 12.59@111.31 Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned |
07-11-2010, 12:00 PM | #8 |
Drives: 6 camaros Join Date: Feb 2009
Did the front bumper cover have to come off?? I just don't feel like pulling it off.
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427 2002 SSLE Convertible 1968 383 Camaro 1968 327 Camaro Convertible 1967 RS 327 1967 Pro-Tour LS3 in progress |
07-11-2010, 01:14 PM | #9 | |
I put the FU back in FUN
Drives: 1969 SS 396 , 2010 Camaro SS Join Date: Jun 2009
Adam you couldnt have said it any better Andy installed one on mine when I did my Cammed Ls3 Conversion WOW I love it BEST MOD NO DOUBT DONE TO THIS CAR Now im not scared to punch on her like I used to since heating the tranny up now is no longer an issue. with 100degree temps the warmest she gets is 180 normal is below 180 This should HELP Very much with the 3200 stall converter im curious what she will run temp wise after the stall. |
07-11-2010, 05:50 PM | #10 |
Yes.
07-11-2010, 07:01 PM | #11 |
Drives: Silver SS/RS, Man 6 Join Date: Apr 2009
DanD - this is the perfect time to do both the tranny cooler and install a Heritage Grill. This is assuming you like the heritage. Anyway just some food for thought. Good Luck
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers, GM 3.91 Rear Gears |
07-11-2010, 09:36 PM | #12 | |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
my trans runs 130-150*f with the yank ss3200, the b&m cooler with fan i put on my camaro is the same one i have used on a couple of my cars and they all ran in this temp range with no problems,,, unless you are running the car in the winter,, you really cant over cool an automatic trans also hook a scan tool to your can and monitor the tcm data, you will see the actuall trans temp data is more accurate than the gauges gm gave us.
415ci stroker, TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, ZL1 Pump, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts, RX can, ADM fuel controller
07-11-2010, 10:09 PM | #13 |
And by looking at your chart I AM EXACLTY RIGHT..170 to 215 is perfect...
Your not implying 140 temps are what u want for the trans?
SOLD
07-11-2010, 10:45 PM | #14 |
why??,, cooler is better, look at the chart
adm performance, trans cooler |
Similar Threads | ||||
ADM Performance Trans Cooler | Melson | USA - Texas | 18 | 06-23-2010 03:17 PM |
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
ADM Performance "Street" & "Race" intakes in stock and ready to ship! FREE SHIPPING!! | Apex Motorsports | V8 Bolt-Ons & Tunes | 23 | 05-22-2010 07:14 AM |
ADM Performance intakes in stock and ready to ship at Apex Motorsports! | Apex Motorsports | V8 Bolt-Ons & Tunes | 7 | 04-25-2010 06:14 PM |
Aftermarket cooling | The_Stache | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 01-11-2010 05:40 AM |
