07-18-2019, 01:15 AM | #1 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Horsepower and gear ratio question
Not sure if this makes sense but, if a 1le has 470 whp and 3.91, what whp would an ss with 3.45 (I think) need to match the 1le acceleration? Just curious.
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
07-18-2019, 02:20 AM | #2 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
1LE trans gearing is different from the SS, making it close to the same final drive ratio. 1LE is still slightly lower from what I researched. So I would say about the same hp. For the 1/4 mile with 470 rwhp, both the 1LE and SS would need to shift into 4th. 1LE 3rd gear tapped out would be about 105 and the SS 113 mph. Depends on where the rev limiter is set or shift point.
07-18-2019, 03:44 AM | #3 |
Drives: Miss Con Ception Join Date: Aug 2016
Divide the gear ratios to find the difference:
3.91/3.45 = 1.13333 All other things being equal, the 3.91 will multiply the torque ~13% over the 3.45 gear. So you would need to multiply the power by 13%. 470 X 1.33 = 532.6 But, as Budbubba points out, the transmission ratios are also different, except for 4th gear (1:1). It turns out that trans*final drive 1st and 2nd are very close to the same, 3rd and 4th the 1LE has an advantage, 5th and 6th are nearly equal again. The shorter tires on the 1LE will also give it a bit more acceleration.
2011 1SS/RS LS3 CGM
07-18-2019, 05:26 AM | #4 |
weSS1LEy
Ah yes that makes sense.
07-18-2019, 06:34 AM | #5 |
Drives: 2014 2SS/RS Join Date: Jan 2018
And yet when you put a stock 1LE against a stock SS in the quarter mile, the SS pulls on the 1LE..
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
07-18-2019, 07:04 AM | #6 |
weSS1LEy
Interesting, can you explain why this might be? This would defeat the purpose of people changing gears?
07-18-2019, 07:21 AM | #7 | |
2014 2SS/RS LS3/M6
07-18-2019, 07:44 AM | #8 |
weSS1LEy
Oh I see so it’s the combination of the trans gears and the rear end. So I definitely won’t underestimate a SS in a drag race then!
07-18-2019, 09:01 AM | #9 |
Drives: 2010 2SS Coupe; 2011 2LT Vert Join Date: Dec 2018
You need to understand the impact of the different transmission gearing in both the 1LE and the SS to determine the Overall ratio first.
Looking at the Overall ratio, you can see that 1st gear, 2nd gear, 5th gear, and 6th gear, both cars are relatively close. However the SS has a slight advantage in 2nd gear and the 1LE has an advantage in 3rd and 4th gear. If the cars are the exact same in horsepower and there is no driver variables to consider, then the SS will pull a little harder in second with the 1LE pulling harder in 3rd and 4th. I would think these cars would be nearly identical in the 1/4 mile in terms of ET with a slightly higher MPH for the 1LE. When you include driver variables, it is anyone's race on otherwise identical cars.
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
07-18-2019, 09:04 AM | #10 | |
07-18-2019, 09:05 AM | #11 | |
Check this out for a good comparison of a gear swap in an SS
07-18-2019, 12:28 PM | #12 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
The camera car is a CMS Stage II cam car. These are the guys that did my car. The other car if im not mistaken is a BTR Stage III cam car.
Bone Stock |
07-19-2019, 03:02 AM | #13 |
weSS1LEy
Wow I had no idea the overall gearing was so close between both cars! So now the question becomes... what the hell is the point of different gears between the two if the overalls end up being almost the same?
07-19-2019, 04:05 AM | #14 | |
