10-11-2018, 12:53 PM | #1 | |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Front Facing Camera for Mylink! 8" Screens Only.
Added the Gen5DIY front facing camera to my 2016 Camaro SS. The install is quick and it works pretty easily. All in for the module update and camera is about $600ish. Not only do you get the Camera, but it will turn back on the option to play videos and unlock all motion locks.
Product: http://bit.ly/2yeePqB
10-11-2018, 08:52 PM | #2 |
2018 Garnet Red ZL1 conve
Drives: 2013 & 2018 ZL1 vert Join Date: May 2009
Still waiting on Ofer to get the harness fixed so it works for the 2018 ZL1.
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
10-12-2018, 02:33 PM | #3 |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Is it 100% reversible? ie can I remove it for warranty work and it doesn't leave a trace?
Sent from my iPhone using Tapatalk |
10-12-2018, 02:35 PM | #4 |
EMERALD COAST CAMAROS
Drives: None Join Date: Feb 2010
The video was almost 30 minutes but what was the actual time it took you to install it?
10-12-2018, 03:01 PM | #5 |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
Did you consider the NavTool GMBOX3.0 add-on module? From what I've read, it adds most, if not all, of the same features/functions as the Gen5DIY HMI update without having to send in your HMI. If you considered the NavTool unit, why did you go the Gen5DIY route instead?
2016 Camaro 2SS, Convertible, Summit White, A8, NPP, NAV, Daily Driver (Sept. 2016-Present)
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
10-12-2018, 03:25 PM | #6 | ||
Drives: 2018 Camaro SS 1LE Join Date: Jul 2010
2007 Colorado I-5 3.7L z85 2wd ext. cab --Totaled 2004 Silverado single cab 4.8l v-8 2wd -- Traded 2018 Camaro SS 1LE -- Current DD |
10-13-2018, 11:14 AM | #7 | |
10-13-2018, 11:35 AM | #8 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Best 1/4 Mile: 12.24 @ 115.9 mph |
10-18-2018, 02:15 PM | #9 |
Lethal Camaro
He has the harness done.
10-18-2018, 02:34 PM | #10 | |||
Lethal Camaro
The benefit of the Gen5 system is it uses all factory stuff to run everything. Yes the upfront cost can be expensive if you don't send in your HMI, but once you get the new one and send your old one in, you get that refund. This is a plug and play setup as well for the most part.
10-25-2018, 08:27 PM | #11 |
Got my front camera harness yesterday and got it partially installed. My HMI area looks different than Lethal Camaro's area when he was installing his. I have asked Jarod for any help. Installation instructions would be really nice. Well see what happens?
11-09-2018, 02:37 PM | #12 |
Front Camera Kit
Well, I finally received my reprogrammed HMI and swapped it into the car and got, "Theft Detected" warning on my info screen in big red letters. So that didn't work at all. Tried swapping them back and forth several times with no luck. So I have sent both the new HMI and my old HMI to the programer today to see if it can be redone and fixed? I'm guessing I'll have to wait another week before I receive it back and try it all over again. I was told by Jarod at Gen5DIY.com that my car is the first 2018 ZL1 to have the front camera kit installation. It took a little while to get everything after they tested the new harness on Ofer's car. I'll let everyone know how it works out and provide some pics and or video.
11-09-2018, 02:49 PM | #13 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Hom we have the first 18 ZL1 with the kit, it is a 1LE but still the ZL1, you and us have the PDM unit down there that the 16 we shot the install with did not have, last thing we fixed the video switch used in the kit, so no more warning when it used.
11-21-2018, 07:14 PM | #14 |
Front Camera Kit from Gen5DIY.com
Ok guys, finally got my original HMI reprogrammed and returned back to me today. Took a little longer than I expected to get it back but just got it installed and everything works perfect now! So nice being able to touch the info screen for the front camera option and seeing what's in front of you. Placed the camera at the very bottom of the grill, you can hardly tell it's there. I highly recommend this mod to all Gen6 Camaro's to prevent damage to your front splitter while trying to park. System will for sure pay for itself if you have to replace your splitter.
Ofer at (Gen5DIY.com) is having some really good prices during their Black Friday sale. I also just purchased their plug & play eyebrow light harness today (on sale). It keeps the eyebrow light on all the time, even with the turn signal blinking. Make sure to check out all their products! Now I will be removing my front bumper to add the Oracle lighting kits.
