Old 04-24-2016, 01:32 AM   #1
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
2016 Camaro Tire Rub Issues 305's+ (Look out for this)
If you plan to go with 305 tires in the rear of your new 2016 Camaro, make sure you verify your tire isn’t going to rub. The spot that most people will get rubbing on is the driver side rear. This is due to a wire harness placement that causes the sound dampening material to bulge out. You will need a spacer or a tire / wheel setup that allows you to avoid this. Or roll with it and reroute the wire harness.
Going with 305 or 315 /30’s on a 11” rim resolved the issues for most.
Sledgehammer70 is offline   Reply With Quote
Old 04-24-2016, 06:36 PM   #2
Mt. Dew
Drives: CM88-B Bison
Thanks for the great video Sledge. So not much wiggle room back there considering the stock 275/35's are roughly 27.6" and a 305/35 is ~28.4" (depending on tread variations). Hopefully the 305/30's at ~27.2" will be fine. Is it purely a tire height issue, or also a tire width issue?
Mt. Dew is offline   Reply With Quote
Old 04-24-2016, 09:02 PM   #3
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Can you lower after rerouting this wiring harness with 35 series tires sledge?
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails.
Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp
Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85
DELIVERED 12/29/15
http://youtube.com/bybcous " no talking only racing on my youtube"
bybcous is offline   Reply With Quote
Old 04-25-2016, 06:43 AM   #4
Fraxum
Fraxum's Avatar
Drives: a M6 LT1 ordered From Becky!!!
Send a message via AIM to Fraxum
Great video OP. Did you also have a jackstand under your car? If not you are a braver man than me.
I am a bit confused too about this. Would the offset on 11" wheels prevent the rubbing?
I am going to put 18'x9.5s and 305-45 DRs on my SS. I will move my wire first anyway. hoping also then to find a way to pull in the inner cover so no rubbing takes place. It would be a shame to get dirt in there.
Fraxum is offline   Reply With Quote
Old 04-25-2016, 10:39 AM   #5
70454
Drives: 1970 Vette,16 1SS, 07 Ford Taurus
I have 305/30/20 on my 20X11 rear rims and have no rubbing issues. The tires aren't even that close to the wheelwell. I checked yesterday after I saw this vid by sledge and maed me paranoid. I think I can even lower the car an inch easily once a company (hopefully BMR) produces a MRC lowering kit. I think if you go with a 305/35/20 that could be a problem because of the overall tire diameter being taller than a 305/30/20 like some have already stated.
70454 is offline   Reply With Quote
Old 04-25-2016, 01:19 PM   #6
Fraxum
Fraxum's Avatar
So the 30s are a little less than 1/2 inch shorter than stock. A good plan anyway to pick up a little gearing on the over geared M6 Ss.
I will be putting on my drs I better have a close look at the tires I think I am buying.
Old 04-26-2016, 08:24 PM   #7
02fbody35th
02fbody35th's Avatar
Drives: 2018 ZL1
Thanks for the video! Please for your safety and also the vehicles safety use a jack stand. I didn't see one in the video and a jack can unpredictably give out at any time!
02fbody35th is offline   Reply With Quote
Old 04-28-2016, 06:58 PM   #8
AdmAnt13
AdmAnt13's Avatar
Drives: '16 Red Hot 2SS M6 NPP
Curious as well with that size or a 315/30?
'16 2SS, M6, Borla Atak
AdmAnt13 is offline   Reply With Quote
Old 06-03-2016, 04:16 PM   #9
exxit
Drives: 2016 1SS D1SC Methfed Lowered Wrapd
Anyone cut a hole premtively during the reroute? I'm debating whether to run 275/40/20's from MT or finding another sticky tire to go with. I've heard of 305's fitting on 9.5's but I dont think the MTs do according to their website
exxit is offline   Reply With Quote
Old 06-03-2016, 05:54 PM   #10
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Its the 11" wheel that's probably causing the issues as much as it is the tire.
Old 07-06-2016, 06:40 PM   #11
ajp
50th Anniversary Vert
ajp's Avatar
Drives: Camaro 2017 50th Anniversary
My dealer said securing the wire harness would impact the warranty???? WTF.
ajp is offline   Reply With Quote
Old 07-06-2016, 08:53 PM   #12
AdmAnt13
AdmAnt13's Avatar
I say relocate it and see if anyone at a dealer even realizes it..
What a joke..
Old 07-06-2016, 09:20 PM   #13
ajp
ajp's Avatar
What a joke..
Agree - dealer wouldnt do it. Had to get 4 new tires (305/30 and 275/30), at least I have my car now.
Old 07-06-2016, 10:18 PM   #14
Sledgehammer70
Lethal Camaro
Added the 4 other videos as stand alone. Can't wait to add more!
