01-12-2022, 07:40 PM | #1 |
Drives: 2011 Camaro SS Join Date: Jul 2017
New shortblock and goals
It's been a crazy 8 months. My 6.0 iron block is coming along. Summit racing LS flat tops and H beam rods. Stock crank. Everything balanced and rings gapped for boost. My cam is a 230/240 @050 116 LS with GM performance lifters. I'm going to replace my ported and rod mod intake with a BTR equalizer and spin this combo to 7500. I'm keeping the Huron single turbo kit but upgraded to the Gen2 7875 and E85. Im keeping the stock heads with BTR dual springs and Ti retainers. I have been contemplating porting or getting some aftermarket heads. I'm hoping for 700ish rwhp thru my 6L80. I also switched to a FTI triple disc and scored some Viking shocks and struts and F14 drag pack with MT tires. My overall goal is 10.50's ET's. Any advice or opinions welcomed!
01-12-2022, 08:00 PM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I'm thinking 10.5s are definitely in your future. Keep us posted!
01-12-2022, 08:09 PM | #3 |
Send your heads over to katech for porting. Or GPI i seen a pair of GPI ported heads, thing of beauty. Do it once.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
01-13-2022, 09:41 AM | #4 |
Evil Genius of Chevrolet
You should be right around there. My mods on 20 inch wheels gave me 10.8's. On 15's or 17's probably a couple tenths faster.
01-18-2022, 08:08 PM | #5 |
I ordered a set of Dart heads instead of porting the stockers. I went with the inconel exhaust valves too for added reliability. Out of the box they are suppose to flow 370 cfm on the intake at .700 lift.
Thread Tools | |
