12-14-2021, 04:18 PM | #1 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
OCTANE LEVEL SWEET SPOT FOR CAMMED 2650 MAGGIE??
Hey Guys, I am putting the car in the shop later this week for the install of Jannettys Terminator Cam / 2650 Maggie package w/ +30 FICs. I am curious to find if there is a octane sweet spot for this build like there is for E (60%) with the JRE 125 Flex Fuel build. I can get 110 race fuel by the barrel, leaded and unleaded. What do you guys think. Thanks in advance.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
12-14-2021, 05:26 PM | #2 |
E60 is still the sweet spot.
2016 NFG 1SS A8
12-14-2021, 05:42 PM | #3 |
I am not going to be able to run ethanol - I'm staying with the stock LT4 fuel system with the JMS voltage booster and +30s the only upgrade. So, is there a particular octane content that is the most efficient? Should I shoot for a 100 octane tune, a 105 or 95? I guess what I'm asking is is the boost in horsepower linear to the octane level? Lastly, since I have no cats, should I run leaded gas?
12-14-2021, 07:23 PM | #4 | |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
12-14-2021, 07:57 PM | #5 | |
Drives: 2018 Camaro ZL1 1LE Join Date: Mar 2021
I know so many people who thought 100 octane was going to be okay.... but then they end up not driving their cars because of fuel limitations. |
12-14-2021, 07:58 PM | #6 |
95-97 using fuel additive put me into the 26-27° degree timing area easily/safely with my 2300.
I'm on 50/50 methanol right now and seems to have put me there plus some in equivalent octane, I can easily reach that level of timing without knock while on 93.
12-14-2021, 08:43 PM | #7 | |
Just run a 93 tune and a race gas tune, youll make about 40hp or so more depending on your build. Your still going to need to watch the high side regardless.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
12-14-2021, 08:57 PM | #8 | |
Mine is a Stage X. I decided to run 100 oct. all the time rather than E because it's so much simpler. There are two 100 pumps within 3 miles of my home. It's obvious I recommend 100.
You'll learn to put camaro1973 on your ignore list as I have. He's a troll. Quote:
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 12-15-2021 at 02:11 PM. |
12-14-2021, 09:03 PM | #9 | |
Hes not asking what you like to do. Hes asking what he should do. And weren't you banned? Shame it wasn't permanent.
12-14-2021, 10:50 PM | #10 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
I would not recommend running that high of an octane all the time on the street. 92-93 for DD purposes is the easiest and simplest way to go. Use 100 octane for a race tune.
My reasoning is that I don't think it's a good idea to always run something at it's max. That can lead to problems like a blown engine. A 93 octane flex tune is where you want to be safely for DD. |
12-15-2021, 05:51 AM | #11 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Sure, higher Oct will net more timing and hp, however, unless you are only bringing the car out for some drag action and constantly running very low tire pressure on drag radials you will not make use of your 93 tune nonetheless a 100+ Oct tune. It is a shame you are not gonna do e since u have the injectors going in.
IMO, most run 100(or MS109 equivalent) as a high Oct tune to answer ur question.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
12-15-2021, 09:58 AM | #12 | |
12-15-2021, 10:08 AM | #13 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
Me and a few others with maggie 2650 cars can't run ethanol unless it's a small blend like E30 maybe. Typically we run on 93 and then use race gas for race days/nights. It's worth anywhere from 50-100 whp.
We have just cam, lt4 system, and dsx low side. No injectors, but I'm not sure how much those would even help. |
12-15-2021, 11:00 AM | #14 |
You may find you can't run full e85, but as JasonGoFast said you could run a blend. Those injectors should help quite a bit in lowering your inj pw. I did the DSX lower aux pump instead of the booster and have no issues on the low side keeping 79-80psi wot. You may ask them to add the Lingenfelter high flow check valve to it. It wont cost a lot and will help keep the flow up.
