10-14-2021, 10:49 PM | #1 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Banks iDash settings
Hey everyone just installed my iDash gauge, what settings is everyone using to see boost, IATs?
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
10-15-2021, 02:23 AM | #2 |
This should help.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
10-15-2021, 06:26 AM | #3 |
Here’s my layout:
10-15-2021, 10:47 AM | #4 |
Dyno Show Queen LOL
I set up the 1st guage to read: (pic may not show)
IAT 1 Generally 1 to 3 degrees of what your radio temp says basically air entering the motor IAT 2 This is the reading that everyone goes nuts about when they have a chiller and they speak of 40 degree IATs. If your exchanger is doing its job it should be with in 10 degrees of ambient temp or IAT 1 IAT 3 (what tuners generally use for timing) also know as MAT this will also be the one that sky rockets for you guys over spinning the oem blower if you see 150s you need cooling mods! HI side fuel pressure Ethanol content Low side or ift pump I have replaced this with IAT 3
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 10-15-2021 at 11:02 AM. |
10-15-2021, 10:58 AM | #5 |
Thanks for the suggestions everyone, there are so many settings on this thing! Does anyone know of a good source to find out what all of those acronyms mean?
10-15-2021, 10:59 AM | #6 | |
10-15-2021, 11:12 AM | #7 | |
Dyno Show Queen LOL
2nd next choose your layout 2, 4, 6, ect on how many to monitor 3rd look for pressures its all in the pressure category. there is a selection for BOOST/PSI under the pressures category. If you have a zl1 it will read the boost it will not go negative like a vacuum only positive! if you have a SS then good luck lol There are also MAP pressures you don't need that unless you have and SS and then there is no guarantee that will work unless you have the right Tmap installed and if that fails Banks sends a pressure sensor that goes from mechanical to digital to read boost for an SS. 4th some of the IAT might be in the Temp section.. Not sure if this will help.. https://www.camaro6.com/forums/showt...0#post11042940
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 10-15-2021 at 11:24 AM. |
10-15-2021, 05:09 PM | #8 | |
10-15-2021, 07:37 PM | #9 | |
Drives: 18 ZL1 Convertible Join Date: Jun 2019
A bit off topic… what is a normal IAT3? |
10-15-2021, 08:01 PM | #10 |
make sure to start with GM parameters in settings or boost will not read and many items above will not be present
10-15-2021, 11:17 PM | #11 |
I did this first, and it restarted, thanks for the heads up Stephen.
10-15-2021, 11:18 PM | #12 |
What is the significance of watching the ECT?
10-15-2021, 11:59 PM | #13 |
There is no normal. It changes with ambient Temps and speed. Anything below 130.
10-16-2021, 12:00 AM | #14 |
It’s good to monitor all Temps. Your dash gauges are dummy gauges.
