07-12-2021, 09:52 PM | #1 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
NEW POWER NUMBERS - SHOULD I BE DISAPPOINTED?
Hey guys, here are the numbers from a stock pull a little over a year ago and the recent pull after installing JRE’s 125 Flex Fuel package. These are uncorrected numbers. With SAE correction it’s at 571 whp. 5.3 pulse width at 29% duty cycle. I am a little disappointed I must admit. I was hoping to get 600 whp.
What do y’all think? Thanks in advance. Sorry about the photo.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 Last edited by MartinLe; 07-12-2021 at 10:09 PM. Reason: Add pic |
07-12-2021, 10:12 PM | #2 |
Drives: 18 ZL1 Convertible Join Date: Jun 2019
So guys who know a heck of a lot more than me will chime in… but ur stock numbers are really low. Most dyno 550-570 or so stock. So either that’s a really low reading dyno or there’s some sort of issue going on.
07-12-2021, 10:14 PM | #3 |
Stock Camaro LT4 should do around 500-520 on Mustang Dyno from what I've seen locally.
07-12-2021, 10:31 PM | #4 |
This is why i hate these damn mustang dynos. Great dyno to tune on but the numbers are all over the place.
Depending on the load of the rollers and model of the mustang dyno i've seen numbers from 5% to like 17% differences from a mustang to a dynojet. This dyno seems to be about 10-11% off from a dynojet based on your numbers. I would assume your making 620+ RWHP on a dynojet so even though it looks like shit on that dyno, your good to go.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
07-12-2021, 11:10 PM | #5 | |
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
07-12-2021, 11:25 PM | #6 |
Drives: '17 ZL1 M6 Join Date: Apr 2021
74whp is a nice bump
If you're looking for a number, just strap her to a different dynojet and see how she does
'17 ZL1 M6
8xxwhp Magnuson 2650 |
07-13-2021, 05:49 AM | #7 | |
Drives: 2019 ZL1 Join Date: Oct 2019
I do have to say though.. 74whp is quite a gap from 125whp advertised for the flex package from Jannetty, not even 60% of claimed gains. Are you on 93 OP or what blend of E? That could easily make up the difference I'd think if not running sufficient E blend. |
07-13-2021, 07:30 AM | #8 | |
Drives: '18 ZL1 1LE Join Date: May 2020
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
07-13-2021, 08:23 AM | #9 |
MartinLe, did you contact Ted and ask him what you are asking on the forum? He is a straight up shop owner that can answer your questions about your concern over the hp gain with your ZL1. I would definitely give Ted a shout is my advice. Good luck.
07-13-2021, 08:58 AM | #10 | |||
That is what I told the tech that ran the dyno. He said that I had a 94 hp bump at the crank which was good. It still seemed that losing 31 hp do to rotational mass, etc., was excessive. Quote:
Thanks guys.
07-13-2021, 10:01 AM | #11 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
That does seem off. I picked up ~100whp on dyno jet using e60 with Teds 125 pkg and I’m at 6000ft altitude (making less boost at altitude). Only difference I see is that I used ARH headers and I used a JMS Booster. I’d definitely call Jannetty and get their input.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
07-13-2021, 12:38 PM | #12 |
What gear was the pull in?
Start with that…I also was tuned on a mustang dyno. 95% of my tuning was done in 6th gear. Final pull was done in 7th gear to get my final number. Some shops don’t like taking there dynos to 180-200 mph spins. My car touches 198. I will post my sheets later, but there was definitely a difference in the 6 vs 7th gear pull.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
07-13-2021, 12:41 PM | #13 |
The tech said I was making 10 psi at 528' elevation on a low 70 degree day. I am going to shoot Ted an email with the pull sheet and see what he says.
07-13-2021, 04:21 PM | #14 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Was this remote tuned by Ted or the shop doing the dyno?
For reference my first round of mods were 9.1 lower pulley, 2" headers with no cats and Rotofab. Car was tuned by the shop that installed with 579whp on a dynojet. I was disappointed as well and felt the car idle and drive very strange. I took the car to MS tuning 5hrs away and on his Mustang Dyno and no changes it made 556whp. He then did the tune and it made 612whp. Tuning is a real big deal! I have since done remote tuning with Ted on last mod revision and I am very pleased with results. |
