Old 01-10-2021, 10:53 AM   #1
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Question Fuel line, check valve question
I plan to replace the factory check valve with the one from Lingenfelter. If I cut the crimped, braided hose from the hardline, is is it possible to use a quick connect fitting on the hardline? Is there already a bulge on the hardline that accepts a quick connect female fitting?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE
Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel.
Elite tuning, results coming soon.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: Swisstyphoon1980
swisstyphoon is offline   Reply With Quote
Old 04-18-2021, 04:47 PM   #2
travislambert
travislambert's Avatar
Drives: '17 ZL1
Did you find an answer on this? I have the same question.
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
Old 04-18-2021, 05:25 PM   #3
swisstyphoon
Yes, there is a bulge on the hardline, but it is not safe with just a new hose clamp, and to short for a quick connect. I ended up cutting the hardline and making a new quick connect flare with a flaring tool.
Or you could also just use a AN hardline adapter like this one. (No flare tool needed) https://www.summitracing.com/parts/EAR-AT165086ERL
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 04-18-2021, 08:16 PM   #4
travislambert
Drives: '17 ZL1
Awesome! Thank you for the detailed response!
2017 Camaro ZL1 M6
Old 11-21-2021, 12:38 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Could anyone share part numbers for this conversion? Did it work for you guys?
Thanks.
'20 ZL1 Black "Fury"
Old 11-21-2021, 02:14 PM   #6
swisstyphoon
Thanks.
Yes it works.
I only have the part number from my link in my post above.
& I used some of those AN quick connect adapters
https://www.summitracing.com/search/...-quick-connect
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 11-22-2021, 07:43 AM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thank you very much!!!
Old 11-22-2021, 03:25 PM   #8
Trochoidal
Drives: 2017 Camaro 2SS A8
Hey Swiss, is this the crimp tool you used? It sure looks the same.
https://www.amazon.com/MASTERCOOL-72...s%2C431&sr=8-1
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“
Trochoidal is offline   Reply With Quote
Old 11-23-2021, 12:12 AM   #9
swisstyphoon
Yes that is the one. I suggest to make some test crimps first on an old line, to get the feel for it. If I remember correctly you have to use the 3/8 quick connect die set, not the 3/8 GM, that is the old style.
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 11-23-2021, 09:06 AM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
So the line and fittings are 3/8"? I thought someone said somewhere it was 5/16". I think that's part of my confusion. What size is on the car? Being a possible failure point (pointed out in another thread), I'm giving this option a little more though. I could be completely wrong on this one.
Thanks for any more information.
Old 11-24-2021, 02:01 PM   #11
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
I just read the thread you referenced, too. Is the check valve necessary? It sounded like the car actually ran (started) better without the check valve? I am having Ted's (JRE) 2650/cam package installed and am wondering if I should swap out the fuel line with the SS one?
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 11-24-2021, 02:11 PM   #12
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
One thing I don't see mentioned in this thread is where whp wise this check valve is actually a concern/restriction... I see 3400-3700 psi (with 70-74 psi feeding it) WOT on my fuel rail pressure during pulls so I haven't found it yet.
I know there are many of us in the 700-900 whp range w/o touching this. Seems easy enough to change but to what value?
LiqTenExp is offline   Reply With Quote
