09-19-2020, 07:44 PM | #1 |
Drives: 2020 ZL1 1LE Shock 1968 Pontiac GTO Join Date: Apr 2020
2020 ZL1 1LE A10 WEIGHT
Put the car on some scales today as well, always good to know the weight!
First is the car with me in it and about 3/4 tank of fuel second is just the car. Ant |
09-19-2020, 08:41 PM | #2 |
3891 isn't bad at all with 3/4 tank of gas. I'm impressed.
09-19-2020, 09:47 PM | #3 |
09-19-2020, 10:13 PM | #4 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Sounds about right. I have an Manual 1LE. This is in kg as I’m in Canada. But 3835 lbs.
09-19-2020, 10:48 PM | #5 |
Nice, I'm going to see what I can do to trim up to 100lbs off my ZL1. I've got a Cox Racing lithium battery that weighs 9lbs, that's a good start to remove 35lbs or more right away. Then I'm going to look into some lighter forged wheels. I've got a set of Kooks headers and green cats coming, I would think those will be lighter than the stock manifolds and certainly doing away with one set of cats should save some weight. Then I've got an AWE exhaust coming, I'm hoping it will be a few lbs lighter as well.
09-20-2020, 07:45 AM | #6 | |
Ant |
01-27-2022, 01:31 PM | #7 |
Drives: 1LEs Join Date: May 2009
Just weighed a 2022 M6 ZL1 1LE (PDR, full tank of gas, all other stock): 3830# with 54.5% up front, 49.4% on left side. Just FYI.
01-27-2022, 01:40 PM | #8 |
Drives: Faster than yours Join Date: Nov 2021
Windshield wiper arms and motor are good for about 10-12 pounds. Windshield washer fluid reservoir another 6-8 pounds. Rear seat delete is 30-ish pounds.
01-27-2022, 01:50 PM | #9 |
Not bad what have you done to lose some weight or is that factory?
01-27-2022, 02:11 PM | #10 |
I believe mine with 2 gal. weighs 3725 with pass. seat., at the strip with Mickey's / F14 it weighs less than 3700
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 01-27-2022 at 04:56 PM. |
01-27-2022, 02:47 PM | #11 |
Rear seat base on ZL1 1LE (with out the regular latch mechanism plus less dense foam than regular ZL1 and SS) was 11# and the seat back was 13.4#. I think my SS 1LE were about 31# for both.
01-27-2022, 03:20 PM | #12 |
If you include the seat belt brackets and seat belt itself you'll get ~30# on the ZLE. I've weighed mine when I removed them.
