12-31-2021, 09:21 AM | #71 | |
Drives: 2014 ZL1 Join Date: Jun 2009
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
12-31-2021, 09:28 AM | #72 | |
12-31-2021, 09:40 AM | #73 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Thank you for the input , and definitely will call monster on the clutch .
Yes I’ve checked everywhere for lsa studs and no dice . according to arp their waiting on raw material from their Pennsylvania distributer |
01-22-2022, 07:11 PM | #74 |
Taking fas enuf lead on this , mapping out the fuel pump access door . Gonna start running my fore fuels system up to the engine bay .
If your considering this mod definitely look up fasenuff vids he’s spot on about starting your pilot hole 2-1/2 “ up and watching out for fuel lines and what not . Picked up set of air metal shears from Home Depot hoping that would do the trick Last edited by Risingson05; 01-22-2022 at 07:25 PM. |
01-22-2022, 07:14 PM | #75 |
Looking good.
01-22-2022, 07:14 PM | #76 |
Got my lid put together and reinforced brick installed .
Think I’m gonna ditch one of the 90’s and go with a straight fitting to discharge to the heat exchanger . Since my trunk tank lines will be coming from back figures feed line would easier being a 90 |
01-22-2022, 07:15 PM | #77 |
01-22-2022, 07:20 PM | #78 |
Rocker arms are ready to go ..
Keeping my fingers crossed for my head studs to be done . I even tried calling shops in Australia and their waiting aswell .. |
01-22-2022, 07:41 PM | #79 |
Yeah I just replaced all my rockers a couple weeks ago with the che trunnions. And almost a completely quiet valve train now. It seems to even run better, I'm thinking because of the increased valve lift because my old rockers were wore out.
01-22-2022, 08:16 PM | #80 | |
Nice !! I really dig the livernois rocker stand kit . They give a wider pedestal base so it tries and minimize the side to side play of the rocker . Figured it would add alittle more valve train stability and the pedestals are less likely to flex with big lift cams |
01-23-2022, 04:19 AM | #81 |
Got the trap door done .
01-23-2022, 07:40 AM | #82 |
great job risingson. well on your way to more power. i can't believe you have the patients to wait for the head studs. if it was me i would have caved in and just went with the arp lsa head bolt set.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
01-23-2022, 08:59 AM | #83 | |
Thank you !! I did try and look for head bolts , from what I’ve seen on the internet there further on back order than head studs . |
01-23-2022, 09:49 AM | #84 |
Man that is awesome!! Good job, and nice and neat too!!
