Old 11-29-2021, 06:47 PM   #15
DannyC
Drives: 17 Camaro SS
grampa, under Torque Model, Torque Calculation, can you give me those numbers because mine is set for Maximum MAP at 99.6 but the reading in my data log is showing 145 lol
Flow Tech axle back, Roto-Fab, Nick Williams 103, AEM Wide Band, Defrost vent pod, billet catch can, BBK long tube headers and NGK LTR6GP, #90198, one step colder, Magnuson 2650, Snow Performance water/methanol injection. (Also tune myself w/HPTuners)
DannyC is offline   Reply With Quote
Old 11-29-2021, 07:05 PM   #16
grampa_ss
grampa_ss's Avatar
Drives: 2016 Camaro 2SS
Max desired MAP = 150.00 kpa
Min desired MAP = 15.00 kpa
Maximum MAP = 99.60 kpa
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth.
grampa_ss is offline   Reply With Quote
Old 11-29-2021, 08:06 PM   #17
DannyC
Wow that's the same as mine. I am still stuck and I don't know anyone local that tunes with HPTuners. Thanks for the quick reply!
Old 11-29-2021, 08:33 PM   #18
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Wiring harness under coolant reservoir isn't damaged/overheated?
You've said you've set the following to max
Torque Management\General\Traction Control System\TCS Method - Max Torque to 6042 and 493°F (you shouldn't have to max this out and -40°F is ok), I don't have mine maxed out on my ZL1 (°F or lb-ft values)
Note: I am not an expert but tune my own car (2017 ZL1)
  • Edit\Virtual Torque - Do you have your Immediate/Predicted torque setup values vs Engine torque values setup properly? You aren't exceeding them and TqtMgAdv (Immediate) is kicking in or even that plus Throttle being decreased (Predicted)?
  • Torque Management\General\Maximum Torque\RPM vs. Gear - Where are you values set to here? Does your log show your Engine Torque exceeding these values when it happens?
  • Torque Management\General\Torque Limit vs RPM\Max Torque\Peak Torque - Where are your values set to here? Does your log show your Engine Torque exceeding these values when it happens?
  • Torque Management\Driver Demand\Desired Torque - Have you looked at MAP A/B/C here, so Immediate can reach the values you are looking for? If TB is closing then this is the place to bump up a little I found, helped my non WOT areas when TB was closing prematurely. DO NOT MAX THIS OUT, adjust it appropriately, do not remove the negative values, you will have bad day!
  • Torque Management\General\Fast Torque Exit - Where are your values set to here? If your Engine Torque vs. Demand isn't accurate you may need to bump these values up. This is associated with transmission based torque requests.
I've never seen these being wrong causing a stabilitrack error on my car, just cuts to timing/throttle. It is still interesting to know where you are with these values.
LiqTenExp is offline   Reply With Quote
Old 11-29-2021, 10:25 PM   #19
DannyC
I've changed everything I can find that controls torque and I'm still stuck going into limp mode.
Old 11-29-2021, 11:02 PM   #20
Kerry
Drives: 2019 2SS Camaro
It can shut the car near all the way down and not go into limp mode something is wrong
Kerry is offline   Reply With Quote
Old 11-29-2021, 11:02 PM   #21
DannyC
LiqTenExp, I copied the ZL1 table so it's at 6042. I have also bumped up the areas you mentioned 5% above. I'll give it a try tomorrow.
Thanks for all the help!
Old 11-30-2021, 08:42 AM   #22
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I'm not sure a 5% change is the right answer. You need to fully review all your tq parameters and see what is out of wack.
Old 11-30-2021, 09:06 PM   #23
DannyC
Ok Kyle found a problem. He said I updated my VTT for my MAF but not the MAP so he fixed it and I see what happens tomorrow.
I am a rookie at tuning and didn't even know there was a seperate table for MAF and MAP. lol
Old 12-01-2021, 05:27 AM   #24
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
VTT you mean VVE?
If you meant VVE:
If you aren't taking the easy/lazy way out of a MAF only tune (which I think is done way too often by lazy tuners) and are keeping Dynamic mode operational you must tune both (Airmass and MAP VVE). I prefer Dynamic (MAF/MAP) operation since the MAP is a lot more responsive. I think I have my Dynamic mode set to go to Hi-Speed (filtered MAF only) around 3500, stock is like 4000.
