10-25-2021, 12:34 PM | #1 |
Drives: 2014 camaro ss 1LE Join Date: Apr 2020
need help with rim sizing
I am currently on 20s and i am going to drop down to 18's.
I know i CAN go to 17's but i cant find a rim i like at all everything in that size is a drag pack type wheel and i just cant find one i wanna put on my car. I am looking at some apex wheels but they only go down to 18's so i have decided 18's are better than the 20's i am on now. I want to get a little sidewall flex. what size can i run up front and out back can i fit a 12 inch wide 18 out back? They make them in a 10 inch all the way to a 12 inch. i am looking for the most tire i can fit under my car without any rubbing as i will be around 1300 wheel and need as much traction as possible. Can anyone help me with a width and an offset on these 18's?
2014 SS 1LE summit white
RWHP 1032 Modifications are as follows: Engine, forged and stroked 416 CI, Procharger F1A-94 with upgraded race intercooler and big red blow off valve, HP Tuner, AEM Wideband with Gauge, TSP Supercharger Camshaft 224/240 .615/.615 112 +3, Brian Tooley Dual Valve Springs, Brian Tooley Chromoly Pushrods and ported heads. Fore innovations twin 450 pumps on E-85 Brian Tooley Titanium Retainers, GM 3 Bolt Conversion, New GM Oil Pump, Injector Dynamics ID 1700 Injectors, Kooks 1 7/8" Long Tube Headers , |
10-25-2021, 03:19 PM | #2 |
I run a 315/40r18 on my race stars.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
10-26-2021, 07:33 AM | #3 |
got any pics from a little further to see how it fills the wheel well up?
What offset are you running?
10-26-2021, 01:39 PM | #4 |
All factory suspension.
10-26-2021, 01:50 PM | #5 |
https://www.beefcakeracing.com/racestar-camaro-pkg/
They are actually on sale right now from the supplier that i got mine from. Close out $620 damn that’s a good price.
10-30-2021, 12:36 PM | #6 | |
Drives: 2010 2SS & 2013 ZL1 Vert Join Date: Mar 2015
10-30-2021, 12:37 PM | #7 |
10-30-2021, 04:55 PM | #8 |
10-31-2021, 09:33 AM | #9 |
10-31-2021, 06:48 PM | #10 | |
10-31-2021, 07:31 PM | #11 |
Yeah they are on the 18x8.5 rim
11-16-2021, 01:26 PM | #12 |
Do you have offset specs on what you are running?
Thread Tools | |
