BeckyD @ James Martin Chevy
Old 09-30-2021, 11:49 AM   #1
ChadSZL1
Red Bull
ChadSZL1's Avatar
Drives: 2017 Chevy ZL1
Question Cam install
I am about to attempt my cam install and I wanted to ask if you guys pull the motor for the install or leave it in? I am also installing a new oil pump and lower. Thanks ☺️
ChadSZL1 is offline   Reply With Quote
Old 09-30-2021, 12:35 PM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
If the heads are coming off I would pull it, otherwise I would leave it in.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 09-30-2021, 01:44 PM   #3
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
The shop that did mine left it in the car. They did pull the nose off the front
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 09-30-2021, 02:46 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
Here ya go https://www.camaro6.com/forums/showthread.php?t=516717 I'm sure there's other video but this one should help
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is online now   Reply With Quote
Old 09-30-2021, 03:18 PM   #5
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Might as well pull it. If you do the oil pump also, you would have to remove the steering gear to be able to get the oil pan off.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE
Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel.
Elite tuning, results coming soon.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: Swisstyphoon1980
swisstyphoon is offline   Reply With Quote
Old 09-30-2021, 06:15 PM   #6
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Seems like it’s just to much hassle to do it in car. Pulling the pump, messing with timing chain and timing alignment. I think most places are just pulling the motor out now.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Camaro1973 is offline   Reply With Quote
Old 10-01-2021, 04:07 AM   #7
Z OH 6
Drives: 2021 Red Hot ZL1
Vengeance Racing pulls the engine to install a cam.
Z OH 6 is offline   Reply With Quote
Old 10-01-2021, 04:24 AM   #8
Sickspeedkuwait
Sickspeedkuwait's Avatar
Drives: '17 ZL1 M6
Mine was pulled out
'17 ZL1 M6
8xxwhp Magnuson 2650
Sickspeedkuwait is offline   Reply With Quote
Old 10-01-2021, 07:17 AM   #9
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
My front subframe was dropped It's more efficient, especially if you are doing Cam, valvetrain, valley cover, oil pump, heads, etc. Less chance to damage car and all you pay is the price of an alignment at the end of the day.
LiqTenExp is offline   Reply With Quote
Old 10-01-2021, 07:31 AM   #10
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
It just takes a few hours to pull the motor. Just pull it, that way you can do a nice clean install on a stand.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 10-01-2021, 08:14 AM   #11
ChadSZL1
Red Bull
ChadSZL1's Avatar
Thanks everyone for the input….. looks like we will pull the motor.
Old 10-01-2021, 08:36 AM   #12
L78toLT1
L78toLT1's Avatar
Drives: Hyper Blue 2016 2SS 6M
If your car is a M6, pulling the heads while the motor is still in the car is easier. It allows the motor to tilt upwards a good bit more before hitting the firewall which will give you the clearance you need to separate the motor and trans
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned
L78toLT1 is offline   Reply With Quote
Old 10-01-2021, 09:00 AM   #13
nighttowl
nighttowl's Avatar
Droppign ths subframe is easier, but one thing that worries me about dropping the subframe is the issues some people had with their electric power steering afterward.
Old 10-01-2021, 09:40 AM   #14
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
This is sometimes done on a manual.
