09-20-2021, 10:34 PM | #1 |
Driveshaft/axles.
Should I upgrade my driveshaft/axles on a 1000-1200whp street duty car?
Car will be used for roll racing, and maybe Mexico… NO launching.
09-20-2021, 11:01 PM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I would keep the factory 2pc driveshaft. It has a higher critical speed and thus safer at higher rpms. I kept mine.
I would also keep the stock axles. Roll racing doesn't break axles. Dig racing and wheel hop does. Plus axles are cheap compard to grenading a trans or diff.
More to come. |
09-20-2021, 11:11 PM | #3 |
That’s what I was thinking since the drive lines not trying to move this fat pig from a dead stop.
09-21-2021, 07:43 AM | #4 |
Drives: 2013 1ss Join Date: Jul 2012
tire choice will be a big factor. If tires are spinning they are also limiting the stress on the driveline. I didnt have driveline issues until i started running street slicks.
09-21-2021, 09:09 AM | #5 |
I gave my stock DS everything it had with no issues. I would stick with stock axles as long as you have the stock carrier. Let those break before you destroy the diff. If you go up to a TruTrac, 1000hp or Renegades would be my choice.
Thread Tools | |
