07-20-2021, 03:08 PM | #15 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
12ish PSI on 91, we don't get 93 in Colorado. I totally get the benefits of ethanol but don't see any need in my situation.
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
07-20-2021, 03:11 PM | #16 | |
I have since added an intake and cat back. Next up is a cam, headers and 2nd cat delete. My goal is 800 wheel, will see what happens
2019 Crush A10
07-20-2021, 05:37 PM | #17 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
07-20-2021, 07:01 PM | #18 |
My mods produce around 765 wheel and it will take Kong's Stage X, and maybe a high side pump and injectors to get to +-815.
'20 ZL1 1LE A10,
07-20-2021, 08:15 PM | #19 |
Dyno Show Queen LOL
On long pulls, when I was stock the 2650 to me drove better in the upper rpm from like 4500 rpm to redline especially when it was hot outside It never felt like it was out of power and it kept pulling hard.. The dyno graphs only showed about a 30 or 40 hp increase over a over driven lt4 but it felt so much better.
Sounds like you don't want to go into the motor for a cam right now... What if you got the. Aem 420 lp hour pump, an aftermarket ecu with wide band, port injectors and toohighpsi fuel rails. Or you can do the Kong ported Eforce that has the port injection allocations, AEM pump, and aftermarket ECU. With one of these setups you can run full E Still.. easily make 800.
07-20-2021, 09:16 PM | #20 |
I ran E85 in my Hellcat for 3 1/2 years straight, daily driver with 28k miles when I sold it. No corrosion issues at all. Modern cars are much more resistant to ethanol.
