Old 07-19-2021, 06:41 PM   #1
Tn4thGen
Tn4thGen's Avatar
Drives: 2017 Camaro
Eibach Lowering Springs
Does anyone have pictures of their car with these springs? I have found some older threads but nothing that has pictures of these specific springs. If you are running them, any comments on the ride? I like the drop of the H&R springs, but the reviews say that they soften the ride.
Yes I know that changing the springs will cost time at the track, and that GM did a fantastic job with this suspension from the factory. Thanks for any help!
Tn4thGen is offline   Reply With Quote
Old 07-19-2021, 08:15 PM   #2
Venomcustom
Hard to want.
Venomcustom's Avatar
Drives: 2020 red hot 1SS 1LE
I went with the H&R and love them. Dropped the car a little over an inch and it runs great on track. It did soften it a touch in touring mode on the street which I like. 99% of the time I’m not on the track. I’m never going to be a professional track rat but on the rolling hills of middle Tennessee the car still feels absolutely amazing.
Venomcustom is offline   Reply With Quote
Old 07-19-2021, 08:50 PM   #3
Tn4thGen
Tn4thGen's Avatar
Drives: 2017 Camaro
Thanks for the feedback! Do you have any pictures of the drop? And any rubbing when you had the car on the track?
Old 07-19-2021, 10:27 PM   #4
sandm
sandm's Avatar
Drives: no more camaro :(
we have done a lot of research into springs. had eibach on my last 4 lowered cars and doing it again.
not sure if you notice or not but there's 2 different eibach springs for the camaro. one drops an inch and is 18-01-22 for the ss. the one you posted lists specifically for the 1LE cars and only drops .7- model 18-03-22.
we are ordering the 18-01-22. I assume the difference has to do with the 1LE suspension being different than the ss?
anyway H&R are great springs. had a set of those once but doing eibach again for this whip and the 01 version should yield the same drop as the H&R.
sandm is offline   Reply With Quote
Old 07-20-2021, 01:18 AM   #5
RynoSS
RynoSS's Avatar
Drives: 2018 Camaro SS 1LE
Eibach Springs on my SS 1LE. They ride amazing and have absolutely zero regrets. I had H&Rs on my A90 Supra and they made all kinds of noises and rode like shit. I'll never buy H&R Springs again for as long as I live.
Eibachs are all I'll ever run, unless it's a fixed, non-magnetic damper setup, in which case I'll run KW V3 coilovers.
2018 Chevrolet Camaro SS 1LE - Hyper Blue Metallic
RynoSS is offline   Reply With Quote
Old 07-20-2021, 06:55 AM   #6
Tn4thGen
Tn4thGen's Avatar
Drives: 2017 Camaro
My understanding is that the .7” drop on the 1LE specific springs is designed to work with the MRC and FE4 suspension that comes on the 1LE. From reading old threads, I don’t think the 18-01-22 spring will drop the 1LE as much as the SS, because of the different dampers.
Old 07-20-2021, 06:58 AM   #7
Tn4thGen
Tn4thGen's Avatar
Drives: 2017 Camaro
Thanks for the info! Do you know if you are running the 1” drop SS springs or the .7” 1LE specific springs? The stance looks great with whichever you have.
Old 07-20-2021, 07:03 AM   #8
Venomcustom
Hard to want.
Zero rubbing on track.
Old 07-20-2021, 09:37 AM   #9
sandm
sandm's Avatar
I believe you are correct. based on 2 products designed differently, my assumption is that they are not meant to be interchangeable. there has to be a reason there's 2 different designs and 2 different drops.
we are going with the 1" ss drop since we don't have a 1LE car.
Old 07-20-2021, 10:34 AM   #10
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Look into BMR, I've had their stuff on other cars and they have lifetime warranty on sag. My eibach experience was terrible sagging .
https://www.bmrsuspension.com/?page=...616&superpro=0
Jaxcam02 is offline   Reply With Quote
Old 07-20-2021, 10:57 AM   #11
FH212
FH212's Avatar
Drives: 2021 Camaro SS 1LE
Damn now I want to lower my 1LE. That sits perfect.
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot
2001 Mecham Trans Am #3 - 7.0L LS1
FH212 is offline   Reply With Quote
Old 07-20-2021, 01:54 PM   #12
RynoSS
RynoSS's Avatar
They are the 1LE specific springs.
Old 07-20-2021, 02:23 PM   #13
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
FYI to all... if you use SS springs on a 1LE the car barely drops is any at all.
Also 1LE's come about 1/2 inch lower than regular SS... makes sense why Eibach has .7 as the drop instead of 1inch like regular SS...
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 07-20-2021, 03:40 PM   #14
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Cereal question, I can barely fit a high end low-profile jack in there as it is...can you still get a jack in when you lower it?
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
