AWE Tuning
Old 12-23-2020, 07:09 PM   #1
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
Question 295/30ZR20 Front Tire?
Has anyone tried 295/30ZR20 tires on the 10" wide rims over the factory 285/30ZR20 size.
When looking at the factory Goodyear Eagle F1 Supercar 3 tires the 295's have a half-inch of additional section width, six tenths of an inch tread width, and two tenths of an inch additional diameter.
I don't see any issues, but someone who's tried the combination might know better. I'm not one to run spacers.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
Old 12-28-2020, 08:58 AM   #2
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
No bit of that is going to turn in to performance on the street or track there's no reason to dabble in a 295/30 unless you just like typing "295/30".
WhiteMale is offline   Reply With Quote
Old 12-28-2020, 12:20 PM   #3
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
I respectfully disagree. More contact = more grip
only disadvantage would be in auto-x, you would have to swing slightly wider through the slalom sections, which will slow your times
h018871 is offline   Reply With Quote
Old 12-28-2020, 01:22 PM   #4
Mountain
Mountain's Avatar
Drives: 2017 SS 1LE, 2016 1SS (previous)
I can tell you there have been people that have run the 305 rear tire on the front SS 1LE wheel. A 295/30R20 will fit on the front 10" wheel, no problem. As far as performance? Eh, I can supply comments of others thoughts (opinions) on potential gains, but it's honestly not going to provide anything more clear than what you can gather right now - which is you will probably lose a bit of steering response and maybe gain a little grip. The 285 GY SC3 already runs a touch on the wide side of a 285...
Honestly, I have been thinking of trying the 295/30 up front, and was going to do it this summer, but my track season was cut a bit and didn't get around to using up my front 285/30 tires to needing replacement... I'm not sure if I will end up trying that out as I feel the 285/30's in the SC3 up front do a pretty good job. In my experience, on an SS 1LE, there is something to be gained to tidying-down the rear a bit over upping tire width on a 10" wheel. Something I'm beginning to find as I push the car more from 9/10ths to my 10/10ths.
Mountain is offline   Reply With Quote
Old 12-28-2020, 04:52 PM   #5
Redlinez
Shifts under load
Redlinez's Avatar
Drives: 2020 Camaro 1SS 1LE rally green
I just installed 295/30/20's on the front of my 1LE. You can see a little bit of tire bulge, but it's not bad at all. I only did it because I got a crazy deal on Bridgestone S007A's.
24 Audi S3 prem plus, sport package
HPDE - southeast - JTI- solo, PCA- blue.
22 Suzuki GSX-S 1000GT blue
Redlinez is offline   Reply With Quote
Old 12-28-2020, 05:15 PM   #6
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
On the SC3s, the OEM size is made specifically for the Camaros, I think the other sizes are likely a different compound that will be softer and warm up faster, prolly not last as long. Better for autox, cooler temps, etc. OEM SC3s love the heat, seems very difficult to get them too hot and it takes a while to warm them up.
DaveC113 is offline   Reply With Quote
Old 12-29-2020, 01:23 AM   #7
Mountain
Mountain's Avatar
There have been some pretty reliable sources that have said the GY SC3 compound is the same across the tire size lineup. The construction is also the same. The difference is the sizes under 265 have a bit different tread dimension setup (more tread void per the tread width) and the tread depth.
Old 12-29-2020, 06:37 PM   #8
Tschw
Drives: 16 HBM 2SS
I have 295s on the front and they do poke a bit but I kinda like the look.
Tschw is offline   Reply With Quote
Old 12-29-2020, 09:15 PM   #9
Markoz28
Drives: 18 ZL1 nightfall grey A10
I’m running 295s up front for about 1 year now and love it.
Markoz28 is offline   Reply With Quote
Old 12-30-2020, 12:29 AM   #10
c4racer
Drives: 2016 SS Convertible
I am running 295/35/19 on 10.5” wheels all around.
It’s a very nice setup. I moved from SS sizes not 1LE.
But the steering feel and response is very good.
Grip is quite good as well.
c4racer is offline   Reply With Quote
Old 01-06-2021, 01:19 AM   #11
oOKhanhOo
Drives: 2018 SS 1LE
Do you have any pics of it? And how well do they tires perform?
oOKhanhOo is offline   Reply With Quote
Old 01-06-2021, 05:24 AM   #12
Redlinez
Shifts under load
Redlinez's Avatar
No pics yet. I'm just daily driving it and it's fine. I'm supposed to go to a HPDE at the end of Feb.
Old 01-06-2021, 09:20 PM   #13
Redlinez
Shifts under load
Redlinez's Avatar
Here ya go
Old 01-06-2021, 09:32 PM   #14
DaveC113
DaveC113's Avatar
Those are indeed black and round.
