BeckyD @ James Martin Chevy
Old 12-22-2020, 06:20 PM   #1
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Hot start - slow crank - fixed! Updated 12/30/20
Like many I have dealt with a slow crank on a hot start pretty much since one year of ownership until now. So that is for about 3.5 years. 1.5 years ago the dealership replaced the battery under warranty for this issue. That kicked the can down the street for about a year. So, for the last 6 months I've been dealing once again with slow cranking on a hot engine.
I saw four paths to follow to attack this problem:
- add a new ground cable
- replace the starter
- replace the battery again
- sell the car
I decided last week to take the path of least resistance and add a new ground cable. So, I spent $40.00 to get one from Lethal Garage. I didn't have high hopes but miracles of miracles - it worked. I have driven the car about 8 times since adding the cable and I have not had anything even close to a slow crank on a hot engine. I have tried to make it happen by adding in short stops with each drive. Today I had four short stops and restarts in one trip. It cranked fine every time. Prior to adding the new ground cable I wouldn't have dared try that! Its the best $40.00 I have ever spent on this car.
If you too are dealing with this - I highly recommend you try adding a new ground cable.
Here is a cold start:
[https://youtu.be/n8Honktafms]
Here is the first hot start:
[https://youtu.be/Z_cqf_TfAm4]
Here is the second hot start:
[https://youtu.be/nyA-AfeJCmk]
I didn't add videos for the 3rd and 4th hot start as they were the same as the first two.
This video shows where I added the new ground cable:
[https://youtu.be/x1Q0s1vw9a8]
Edit: I just went back and listened this video and realized I failed to mention that the engine bolt I used is part of the serpentine belt system. I didn't take the bolt all the way out. I just loosened it and then cut a small piece out of the ear of the lug and slid the lug under the bolt and tightened it down. If you take the bolt out all the way you will lose tension on the belt.
Update 12/30/20: With the saying in mind that if one is good then two would be better - I added another ground. This time I took on the other end of the car and added another ground from the battery's negative post to the floor of the trunk. This cable is a little smaller (2.0 guage) and I bought it off of Amazon for $14.00. I placed the body end of the ground on a unused threaded stud sticking up out of the trunk floor (look to the lower far left in the photo). I have no idea if another ground is helpful and needed . I just added it for peace of mind - plus it was easy and cheap.
Please pay attention to the edit I added with the last video on cable location for the engine ground. Do not remove the belt tensioner bolt I used. If you do you will lose tension on the serpentine belt. Instead cut a small piece out of the cable's terminal lug making it look like a U and then slide it under the bolt. You can back that bolt out enough to slide the lug under it and tighten.
I continue to have normal starts whether the engine is cold or hot.
Name:  Secondary battery ground.jpg
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 12-22-2020, 06:34 PM   #2
TMD29
TMD29's Avatar
Drives: 19' ZL1, BMW F80 M3
Can't see the videos. They are listed as "Private".
TMD29 is offline   Reply With Quote
Old 12-22-2020, 06:44 PM   #3
SSDan
SSDan's Avatar
Opps! I just went into youtube and made them all public. Thanks for letting me know.
Old 12-22-2020, 06:48 PM   #4
CamaroJim56
Obsessed
CamaroJim56's Avatar
Drives: 2016 Hyper Blue 2SS RS
So, just got a 2016 2SS, what happens when they get hot and you try to start?
Thanks,
Jim
2016 Hyper Blue 2SS
CamaroJim56 is offline   Reply With Quote
Old 12-22-2020, 06:57 PM   #5
SSDan
SSDan's Avatar
Thanks,
Jim
The starter will crank so slowly that it may scare you that it will not start. Mine always did start but a couple of times it almost failed to start. It does not inspire confidence that is for sure. And for some people the start will fail totally. Believe me you will know if you get the problem. Its very distinctive!
Old 12-22-2020, 07:55 PM   #6
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
The usual culprit of this is heat soak from the exhaust manifold, more pronounced with headers but it can happen stock. Get yourself one of these also.https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Warrior102 is offline   Reply With Quote
Old 12-22-2020, 07:58 PM   #7
shaneotool
Drives: 2016 Camaro SS
Is there a write up somewhere on where this ground cable goes?
The real test may be in july/august...
shaneotool is offline   Reply With Quote
Old 12-22-2020, 08:25 PM   #8
Mike Aruba
Mike Aruba's Avatar
Drives: 2016 2SS
Curious about a write up as well. Can you provide a link to the cable you ordered?
Mike Aruba is offline   Reply With Quote
Old 12-22-2020, 08:32 PM   #9
SSDan
SSDan's Avatar
No doubt a starter blanket may help. I’m just sharing what I’ve found. Poor grounding plus excess heat equals added resistance to electron flow. If the battery can’t overcome that resistance then insufficient voltage is available to crank the starter. A new ground cable attacks one end of the problem equation by reducing resistance. The starter blanket might help with the other end of the equation which is heat soak. BTW I bought a starter blanket a while back but was unsuccessful getting it to fit around the starter. It’s a very small and tight space to work with.
I showed where I installed the cable in the last video. It’s pretty straightforward. No doubt the summer heat can make this even worse but my car suffered from slow cranking in any weather whenever the engine was fully warmed up and I made multiple short stops.
Old 12-22-2020, 08:59 PM   #10
I`m Batman
I`m Batman's Avatar
Drives: 2016 Camaro SS M6
Can you share a link to the item? That's a cheap item to install and couldn't hurt. I've never had the problem but why not?
I`m Batman is offline   Reply With Quote
Old 12-23-2020, 12:12 AM   #11
MackSteelPrivateEye
Drives: 6 on the Flo' Super Sport
- sell the car
So GM has a class action Lawsuit out for this instead of them just adding a proper ground cable?
Anyone call them and tell them how to fix it?
MackSteelPrivateEye is offline   Reply With Quote
Old 12-23-2020, 12:15 AM   #12
MackSteelPrivateEye
Anyone call GM and tell them this is whats needed? Or do they want to try and fight the class action lawsuit out against them.
Old 12-23-2020, 12:25 AM   #13
MackSteelPrivateEye
- sell the car
Here's one for $14
https://www.autozone.com/batteries-s..._0_0?rrec=true
Old 12-23-2020, 12:34 AM   #14
MackSteelPrivateEye
I can't say I have the issue. But I have over 42k miles on it now. My concern was how difficult to add that heat shield as a precaution. How difficult would it be to install if the car was on a lift?
