Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
BeckyD @ James Martin Chevy
Old 12-31-2018, 01:30 PM   #1
Destroyer_1LE
Destroyer_1LE's Avatar
Drives: 2017 Camaro 1LE
How to Bleed/ Flush Brake and Clutch Fluid System
How To Bleed/ Flush Brake and Clutch Fluid System (with a Motive Power Bleeder)
Tools/ materials needed
1. 7/8th brake wrench or 7/8th open ended wrench
2. Small screwdriver
3. 3-8 bottles of brake fluid (best to have extra on hand)
I'm using Motul 660 DOT 4 brake fluid
https://www.amazon.com/Motul-847205-...ords=motel+660
4. Motive Products 0118 Black Label GM/3-Tab Power Bleeder Kit (I recommend getting Black Label because it comes with a aluminum cap which seal much better than the normal plastic cap)
https://www.amazon.com/Motive-Produc...ve+black+label
5. Motive Products 1820 Brake Fluid Catch Bottle Kit
https://www.amazon.com/Motive-Produc...JC6TEPR432RHGC
6. Large Syringe with tube
7. Empty gallon jug
Optional
1. Help or a friend
2. Jack
3. Jack stands
4.Wheel chock
5. Cold beverage of your choosing
I took photos to help step by step, however I lost my SD card (If I find it I will updated the post) Sorry :(
Steps
1. Remove brake master cylinder reservoir cap
2. Take your large syringe and insert the tube into brake master cylinder reservoir and siphon out old contaminated fluid.
3. Take old contaminated fluid and put into your empty contaminated fluid jug
4. Open 1 bottle of brake fluid of your own choosing (I’m using Motul 660 DOT 4)
5. Fill the brake master reservoir up to the top fill line (fill level marks can be found on the left side of reservoir if looking from the front of the engine bay)
6. Leaving the car off get your Camaro and pump the clutch fully 100-200 times (making sure it has a solid pebble feel)
7. Take your large syringe and insert the tube into brake master cylinder reservoir again and siphon out contaminated fluid
8.Take contaminated fluid and put it in your contaminated fluid jug
9. Refill reservoir again up to the top fill line
10. Get back into your Camaro and pump the clutch again 100-200 times (making sure it has a solid pebble feel)
11. Take your large syringe and insert the tube into brake master cylinder reservoir again and siphon out contaminated fluid
12. Take contaminated fluid and put it in your contaminated fluid jug
13. Refill reservoir again up to the top fill line
14. Now prepare your motive power bleeder by filling the tank with 2 quarts or 4 bottles of brake fluid of your choice and screwing on pump cap
15. Now screw on motive power bleeder cap onto the brake master cylinder reservoir
16. Pump the motive power bleeder till 15 psi is reached
17. Wait about 5 minutes to check for leaks, confirm by still having 15 psi in the motive power bleeder after waiting 5 minutes
18. Now make your way to the passenger rear wheel (this is where you have two options)
1. Bleed only the outside bleeder
2. Bleed inside and outside bleeder (If you are changing to a different fluid then which is already in the brake system you MUST use the inside, outside method as you need to completely flush out the different old contaminated fluid)
19. If you choose to bleed inside and outside bleeder this is where you would jack up the car and place it onto jack stands and remove the wheels. If you choose to bleed only the outside bleeder you can do so without taking off the wheels through the wheels spokes. Then proceed to step 32 and repeat in the order (passenger rear, driver rear, passenger front, driver front)
20. Once wheels have been removed locate the passenger rear inside brake bleeder nipple and remove rubber protective cover with a screwdriver
21. Take your Motive brake fluid catch bottle and slide tube over the inside brake bleeder nipple
22. Take your 7/8th brake wrench and place it onto the inside brake bleeder nipple
23. Go back to the Motive power bleeder tank and confirm it still has 15 psi
24. Now crack open the inside brake bleeder nipple until fluid starts flowing.
25. Let fluid flow and go back to power bleeder to confirm brake fluid starts to fill the power bleeder tube leading to the brake cylinder reservoir automatically filling the reservoir with fresh fluid keep it at the top fill line (continually check that the system is still pressurised at 15 psi. It will drop as you bleed the system and pump it back up as needed)
26. Continue to allow fluid to flow until your start to see new uncontaminated fluid with no bubbles in the brake fluid catch bottle tube.
27. Once you start to see fresh fluid and no bubbles close the inside brake bleeder nipple
28. Remove the Motive brake fluid catch bottle tube and empty contaminated fluid into your contaminated fluid jug
29. Now reattach your Motive brake fluid catch bottle tube onto the inside brake bleeder nipple now repeat steps 22-27 confirming only fresh fluid and no bubble are coming out along with making sure the system is pressurized to 15 psi and new fluid flowing into the brake master cylinder reservoir
30. Once confirmed that only fresh fluid and no bubbles are coming out repeat step 28 (Remove the Motive brake fluid catch bottle tube and empty contaminated fluid into your contaminated fluid jug)
31. You have now flushed the inside brake bleeder nipple of the passenger rear
32. Now locate the passenger rear outside brake bleeder nipple and remove rubber protective cover with a screwdriver
33. Take your Motive brake fluid catch bottle and slide tube over the outside brake bleeder nipple
34. Take your 7/8th brake wrench and place it onto the outside brake bleeder nipple
35. Go back to the Motive power bleeder tank and confirm it still has 15 psi
36. Now crack open the outside brake bleeder nipple until fluid starts flowing.
37. Let fluid flow and go back to power bleeder to confirm brake fluid starts to fill power bleeder tube leading to the brake cylinder reservoir (continually check that the system is still pressurised at 15 psi. It will drop as you bleed the system and pump it back up as needed)
38. Continue to allow fluid to flow until you start to see new uncontaminated fluid and no bubbles in the brake fluid catch bottle tube.
39. Once you start to see fresh fluid and no bubbles close the outside brake bleeder nipple
40. Remove the Motive brake fluid catch bottle tube and empty contaminated fluid into your contaminated fluid jug
41. Now reattach your Motive brake fluid catch bottle tube onto the outside brake bleeder nipple now repeat steps 33-39 confirming only fresh fluid and no bubbles are coming out along with making sure the system is pressurized to 15 psi and new fluid flowing into the brake master cylinder reservoir
42. Once confirmed that only fresh fluid and no bubbles are coming out repeat step 40 (Remove the Motive brake fluid catch bottle tube and empty contaminated fluid into your contaminated fluid jug)
43. You have now completed flushing the passenger rear inside and outside of the brake caliper.
44. Repeat step 19-43 in this order (inside passenger rear, outside passenger rear, inside driver rear, outside driver rear, inside passenger front, outside passenger front, inside driver front, outside driver front)
45. Now you have completed flushing and bleeding all four brake calipers
46. Slowly unscrew the pump cap on the motive power bleeder (once you see pressure start to drop on the gage allow it to do so slowly once pressure has reached zero unscrew the cap.
47. Now remove the motive power bleeder brake cylinder cap
48. Place your motive power brake bleeder off to the side out of the way
49. Confirm the brake master cylinder reservoir is filled to the top line (if needed fill with new fluid)
50. Put on the brake master cylinder reservoir cap
51. Go around your Camaro one more time looking at the inside and outside brake bleeder nipples and confirm they are not leaking and tight
52. Put your wheels back onto your camaro and take it off the jack stands (do not put the rubber protective brake bleeder nipple cap on yet as you want to inspect the brake bleeder nipples again in the next few steps)
53. Get into your Camaro and pump the brakes confirming it has a solid feel if not go back and repeat the whole process as there is possibly air in the system (DO NOT DRIVE IF YOU DO NOT HAVE A SOLID BRAKE PEDAL FEEL)
54. If you have solid brake pedal feel, you can now check your clutch pedal confirming it has a solid pedal feel if not repeat the whole process as there is possibly air in the system (DO NOT DRIVE IF YOU DO NOT HAVE A SOLID CLUTCH PEDAL FEEL)
55. Now start your Camaro and check both pedals for solid feel again
56. Once again get out of your Camaro and check the brake bleeder nipples for leaks and confirming there tight
57. Once you have found no problems with the system with the car running put in the clutch and put transmission into gear keeping the clutch depressed (DO NOT FORCE IT)
58. Repeat step 57 multi times in each gear
59. Now your ready for a test drive
60. Slowly start to drive your car in a safe space (DRIVE SLOWLY)
61. Apply the brake confirming the brakes are stopping the car
62. Slowly start adding speed and using more brake force
63. Once the brakes check out and are working correctly, go around your Camaro one more time check the brake caliper bleeder nipples for leaks and making sure there tight
64. Open your hood and check the brake master cylinder reservoir level (fill if needed)
I recommend taking the car for one last test drive confirm the brakes work correctly as this is a key part of your safety and everyone around you
65. Now you can put the rubber protective brake bleeder nipple caps back on
66. Over the next couple of days or drives check for leaks and brake master cylinder reservoir fluid level
Congratulations you have completed bleeding/ flushing brake and clutch system
2017 Camaro SS 1LE
Instagram: @Destroyer_1LE
Sponsor: Tires: Michelin, Wrap: Protective Film Solutions, Wheels: APEX RACE PARTS
Destroyer_1LE is offline   Reply With Quote
Old 01-24-2019, 12:17 PM   #2
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Thanks!
But I got a question on step 2 and 3.
I don’t know About std ss, but I have a 2017 zl1.
The brake reservoir appears to have 2 compartments....
Siphoned the front, unable to syphon the aft?
Add dot 4 in the front
Got 2 different colors clear front, dark aft.
Did 100-200 clutch
Didn’t mix??????
Any idea
Drove the car
Had hard braking to make the ABS work
Still not mixing???
Will it flush when I will pressurise and let it flow trough the calipers?
Will it fill again after?
Still perplex about this kind of second compartment....
Biscuit.fr is offline   Reply With Quote
Old 01-24-2019, 12:41 PM   #3
Biscuit.fr
I put in red the limit I can see between the front (clear dot4) and the aft (dark dot3)
plus kind of a flush plastique part for the "second compartment"
The only way I see to flush the aft is to twist or cut the plastique surrounded in red, and try to find a cap to close it after...
Any ideas?
is it an additional reservoir for the ABS or something else?
why doesn't it syphon from the front?
why doesn't it mix with 100 clutch or pressure?
when I syphoned the front reservoir the aft was still up max?
Old 01-24-2019, 12:54 PM   #4
Biscuit.fr
forgot to say
it's a A10
so no clutch pedal,
just brake pedal
what about the e-brake?
does it have to be released before the procedure?
Old 05-03-2019, 08:50 PM   #5
artey34
artey34's Avatar
Drives: 2018 Camaro 2SS 1LE - Hyper Blue
Did you ever find photos to add to this post?
artey34 is offline   Reply With Quote
Old 05-30-2019, 11:19 AM   #6
verdicaysen
verdicaysen's Avatar
Drives: 18' 1SS 1LE HyperBlue
I'm going to assume not. It's a great walk through. I'm still a bit nervous about doing it as it will be my first time - but if nothing else i'll video call someone that's done it and have them make sure i'm not killing myself.
verdicaysen is offline   Reply With Quote
Old 07-08-2019, 09:51 AM   #7
spenceryan
Great help.
I was able to do this yesterday following these instructions and they worked great. This was my first time bleeding and flushing brake fluid ever. Ended up using two liters of ATE Typ 200. The original DOT 3 Brake fluid that was in the car was fairly new so I really could not see a color change so probably used more than I needed.
spenceryan is offline   Reply With Quote
Old 07-08-2019, 09:54 AM   #8
rlarsen462
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound)
To ease your mind, I did this exact procedure as well with SRF using about 1.5 bottles (I think they are quarts) and tracked the car Friday with zero fade, brakes were perfect for 20-30 minute sessions. I registered caliper temps around 350F so it wasn't pushing the temp limits necessarily but it worked great.
rlarsen462 is offline   Reply With Quote
Old 01-16-2020, 11:00 PM   #9
waterman
waterman's Avatar
Drives: Grandad's C2 L89
With no slave cylinder/reservoir present, I was struggling to find a clutch bleed method. I had a tiny bit of an OEM DOT3/Prospeed RS683 blend going on in there. Although compatible not what I was hoping for.
I missed this post last year.
Thanks for posting Destroyer_1LE.
2018 ZL1 1LE sw/PDR
waterman is offline   Reply With Quote
Old 06-09-2020, 05:08 PM   #10
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
Unfortunately, Amazon messed up the motive bleeder you have listed. Sent me the regular screw on reservoir cap not the gm 3 Tab. I didn't realize it until I had already filled the power bleeder. I guess I'll just keep it sealed until I can find the right one.
eimarshall is online now   Reply With Quote
Old 08-05-2020, 03:08 PM   #11
Coded4SS
Drives: 2020 1SS 1le
Subscribed
Coded4SS is offline   Reply With Quote
Old 08-06-2020, 09:10 AM   #12
68Vette
Drives: 1SS Hyper Blue Metallic, MRC, NPP
Subscribed-
68Vette is offline   Reply With Quote
Old 08-06-2020, 06:09 PM   #13
parbreak
Drives: 2017 50th Camaro SS
This might be the single most detailed brake bleed instructions I have ever seen in my life!!
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 12-07-2020, 04:59 PM   #14
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Error in your bleed order Step 44. This is per the GM service manual:
1. Inside passenger rear, outside passenger rear,
2. Inside driver front, outside driver front)
3. Inside driver rear, outside driver rear,
4. Inside passenger front, outside passenger front
It's done on a diagonal due to the way the brake lines are connected, which is in a diagonal from right rear to left front and then from left rear to right front.
I've actually done it just about every way there is and haven't noticed any difference, but follow the service manual now.
FYI you can access the service manuals for as little as $15 here www.repairprocedures.com
carguy55 is offline   Reply With Quote
