Old 02-15-2017, 01:00 PM   #1
WhyUMad1LE
Drives: 17 SS 1LE
Amp Location In 1LE?
***UPDATE 12/27/21***
My setup: https://www.camaro6.com/forums/showt...8#post11113148
***UPDATE 3/30/21***
To clarify, the information below pertains to 2017 & 2018 model years. 2019 and newer switched to a different CAN bus protocol (GM-LAN).
***UPDATE 1/21/19***
There is no external amplifier in the 1SS 1LE. It has a chip amp integrated into the HMI which is located under the glovebox. You can see the location at 6m24s in this video (although the Camaro in video is not a 1SS 1LE, all 6th gens have HMI mounted in the same location):
To grab the signal digitally without amplifying the system chimes, we can use the NAV-TV M650 ($850), PAC AP4-GM61 ($200~$400), and Axxess AX-DSP/AX-DSP-X with AX-DSP-GMLAN09 harness (~$400).
FYI radio using the PAC will be mono and not stereo. The AX-DSP will lower the driverside speaker volume when chimes turn on. AFAIK no one has tried the NAV-TV on a non-Bose system.
If you have a line out converter you would like to use and don't care about loud chimes, you can try this harness: https://lljcustoms.com/store?olsPage...-amp-t-harness
ORIGINAL POST:
I want to hook up a different amp to the stock speakers. I see there is a subth ump harness but we have the MRC module where an amp is supposed to be? Anyone know where it's located?
Should look like this:
WhyUMad1LE is offline   Reply With Quote
Old 02-15-2017, 01:13 PM   #2
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
This POS stereo has a separate amp lol?
Old 02-15-2017, 02:07 PM   #3
WhyUMad1LE
Drives: 17 SS 1LE
It's not as bad as you make it out to be, just stop using bluetooth lol.
Old 02-15-2017, 04:11 PM   #4
davef
Drives: 2017 SS 1LE Garnet Red
Apparently it's behind the passenger side rear plastic panel. So if you were sitting in the passenger rear seat it would be on your right.
davef is offline   Reply With Quote
Old 02-15-2017, 09:32 PM   #5
WhyUMad1LE
Drives: 17 SS 1LE
Thanks, I will check that out.
Old 03-17-2017, 11:23 AM   #6
kparker
kparker's Avatar
Drives: 2017 SS 1LE Artic Blue
I looked around the rear passenger seat area for a panel. I didn't see one. Any pictures of a SS 1LE amp? and confirmation where it's located
SS 1LE PDR Artic Blue (VBWZZJ )
ordered - 1/17/2017
1100 - 1/27/2017
3100 - 2/06/2017 TPW 2/27
3400 - 2/21/2017 TPW 2/27
4200 - 2/28/2017 Built 190751
delivered - 3/5/2017
kparker is offline   Reply With Quote
Old 03-17-2017, 11:30 AM   #7
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
I don't have a 1LE but I'm fairly certain its in the trunk same as the Bose location. In the "spare tire" well.
Obzen is offline   Reply With Quote
Old 03-17-2017, 11:54 AM   #8
TJay74
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC
And you would be wrong if you assumed this without looking. On the 1LE cars the MRC controller is located in this location. It is located inside of the interior where someone else just pointed out.
TJay74 is offline   Reply With Quote
Old 03-17-2017, 01:59 PM   #9
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Well that's just silly.
Old 03-17-2017, 03:15 PM   #10
davef
Imagine that you're sitting in the rear passenger side seat. The plastic panel where your right elbow is has to be removed to see the amp. I haven't done it yet but it is not an access panel, it's the interior panel that needs to be removed. Probably some pop rivets and a screw or two. You may want to call Crutchfield, they may have some info on disassembly of the interior.
Old 03-17-2017, 03:34 PM   #11
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
The side panels come off sorta....kinda...easily.
If you pop off the airbag tag in the rear panels, there's a couple screws behind it after that the panels pull off. It's easier if you remove the rear seats first but can be done with them in.
http://www.camaro6.com/forums/showthread.php?t=447779
Old 03-17-2017, 04:23 PM   #12
kparker
kparker's Avatar
Thanks guys. I was looking for an access panel but now I understand that its the interior panel.
ordered - 1/17/2017
1100 - 1/27/2017
Old 03-17-2017, 04:56 PM   #13
Summit1le1ss
Drives: 2017 1ss1le
look under your tire cover and lift up that foam holder for the air pump. I saw something that looked like an amp.
Summit1le1ss is offline   Reply With Quote
Old 03-18-2017, 08:37 AM   #14
MrAl
Drives: 2017 Camaro SS 1LE HBM
This thread is useless without pictures.... :-)
Mr Al
MrAl is offline   Reply With Quote
