Old 12-21-2016, 11:42 AM   #1
slick3
Drives: Garnet Red - 20 ZLE
Check Engine Light Question?
Car is under warranty still but figured I would throw this out there in case its an easy fix, Im not without my car for a week.
P06DA
P06DB
Engine light came on and said reduced power. Car drives fine and idles normal when the code is cleared. Has good oil and fuel pressure from what I can tell. Any GM tech's could chime in maybe and let me know what you think
2017 SS M6
slick3 is offline   Reply With Quote
Old 12-21-2016, 02:10 PM   #2
slick3
Found out the issue. You guys might want to check for this next time you are under the hood. Car has 300 miles on it btw... This is the sensor located directly to the right side of the crank. It is a pressure actuated solonoid harness to regulate oil pressure.
Thanks to Tim, @ EFI Tuning for help me get this figured out. Im going to try and fix it myself, unless the engine goes bye bye, there is no way this thing is going back to the dealer.
Old 12-21-2016, 02:26 PM   #3
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Is the issue with how that wiring harness is routed and it got too close to the belt which chewed a hole in it? I may be stating the obvious but sometimes you don't see all you need to know in a photo.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 12-21-2016, 02:37 PM   #4
slick3
You are on the money.
Old 07-09-2020, 09:05 PM   #5
AlphaCamaro7
AlphaCamaro7's Avatar
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85
hey can you repost the pictures? I am also dealing with the code P06DA and I wanted to know what you did to fix it?
Well............ At least you tried. lol
AlphaCamaro7 is offline   Reply With Quote
Old 07-10-2020, 01:32 PM   #6
oOKhanhOo
Drives: 2018 SS 1LE
Look down between the engine and radiator fan. It’s in the bottom right area. You should see a big wire harness that’s wrapped in tesa tape.
oOKhanhOo is offline   Reply With Quote
Old 07-30-2020, 06:45 PM   #7
Ghostog27
Ghostog27's Avatar
Drives: 2017 1LT Camaro
I’m throwing this code! What was the fix?
Ghostog27 is offline   Reply With Quote
Old 02-27-2021, 11:52 AM   #8
koolkat68
Drives: 2022 Vivid Orange Metallic LT1
I have the same code. Here is a pic of what is wrong.
koolkat68 is offline   Reply With Quote
check engine, p06db, po6da
