12-10-2020, 12:59 PM | #15 |
Drives: Duramax, 2018 Camaro SS 1LE Join Date: Nov 2020
Take your 7/8th brake wrench and place it onto the inside brake bleeder nipple
Those are some big bleeders LOL.
If it ain't buckin, chirpin & makin all kinds of bad noises.... then I ain't happy!
11-04-2021, 02:32 PM | #16 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
I believe he meant 7/16th's (at least that fits my standard 2017 SS's brakes).
But I found an 11mm box wrench to be a bit better (snugger). Also, I prefer to use the box end placed on the bleeder valve first, then the tubing to drain into. The tube holds the wrench in place, just orient the wrench to be ready to open the valve, then open and close as needed. When finished with that side, just repeat in the order carguy55 updated. Just my 2 cents worth. Thank you OP, great post! One last thing, just in case you're not aware- bleeder valves are made of brass (soft stuff) and the Brembo caliper is aluminum. Do not over tighten. Tighter to be sure is not better and may result in stripped threads and leaks. Wish I could provide an inch/pound spec. but I don't know it. Update: I've seen a spec. here on C6 from Member Alpha1BC that quotes Brembo torque specs as 17-20Nm or 150-177in/lbs for the bleeder valves (that would make the high value at 14.75 FT/lbs). Spark plug torque spec is 10lbs I believe. This number seemed a little tight to myself and a few other members. My valves are sealing well at 80in/lbs or 9.0Nm. Use your best judgement but if you don't have experience with bleeder valves, please use a torque wrench not a dork wrench. Last edit- Spoke to my Subaru Service Center today and their torque spec for my CrossTrek bleeders is 70in/lbs. OK- last, last update- just saw service manual document #5613487 stating bleeder valve torque spec is 97 in/lb = 8.33 lb/ft. LAST- last update- 97 in/lb is correct for the rear bleeder valves but the spec for the front calipers is in fact 13-15 lb/ft. For the record. My apologies to Alpha1BC! Last edited by Ventmaster; Today at 01:00 PM. |
11-11-2021, 03:29 PM | #17 |
Finished my first bleed using the Motive Power Bleeder. Keep in mind if you follow this procedure you will be using using about 550ml of brake fluid just to flush and refill the master cylinder 3 times (I could extract about 180ml each time I pulled out the dirty stuff). My bottles held 500ml each (Motol 660) and I had 4. Long story short, it took 3- 500ml bottles to complete the job to my satisfaction- one just for flushing and refilling the m/c prior to Power Bleed and 2 more to bleed the lines and both bleeder valves on each caliper.
I haven't done a shake down drive yet but the clutch is firm and the brake pedal is hard. Held my breath and took the car out knowing there was some chance I'd introduced air into the system, but I'm happy to report the pedal is rock hard firm and the car will stop on a dime! I strongly recommend anyone with a 5 year old car (I have less than 17K miles on her and live in a low humidity environment) go ahead and bleed out the old fluid. you won't regret the effort. Last caveat- when opening the bleeder valve don't get in a hurry and open it much more than a 1/4 turn. Keep in mind the "valve" is threaded on both ends and if you remove it too far it is going to allow air to be drawn in around it, giving the impression you're bleeding air out of the system when you are not. You could be there all day and waste a lot of brake fluid. In short, take your time. Last edited by Ventmaster; 11-25-2021 at 12:05 PM. |
01-29-2022, 09:00 PM | #18 |
Drives: Chevy Camaro, Dodge Charger Join Date: Oct 2021
Resurrecting this old thread, glad I found it as I’ll be changing my fluid over before I hit the track this spring. I’ve bleed brakes many times on automatics and didn’t even think about the clutch.
My question is this, shouldn’t there be an easier way to drain the clutch fluid? There isn’t a clutch bleeder someplace? I have a couple liters of castrol SRF on standby for when I go to do this but at $70 a pop Id prefer not to have to buy a third.
2022 SS 1LE 2SS 6MT on order. BDZHD3
05-31-2022, 09:07 PM | #19 | |
Drives: 2018 SS 1LE Join Date: Sep 2018
There is a bleeder but in a spot that's very difficult to get to. There are company that sells TR6060 Bleeder Extension Line. Below is a pic of the TR6060 Transmission from the SS. The bleeder screw is on the left side in the middle of the pic at the bell housing, you can see the rubber cap on it. I got the pic from this thread: https://www.camaro6.com/forums/showthread.php?t=471480 |
08-09-2022, 05:09 PM | #20 | |
Drives: 2020 Chevrolet Camaro 1LT 3.6L supe Join Date: Jan 2022
01-25-2023, 02:55 PM | #21 |
Bump for sticky status
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
01-27-2023, 08:17 AM | #22 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I only ever bleed my brakes with 1 bottle of SRF castrol and I don't bother with the clutch pedal. No issues here so far and I basically only track my car. It barely sees street miles.
05-01-2023, 02:18 PM | #23 | |
Driver for Hire
I have a video on this, specifically how to do it without help, here:
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel |
