Old 08-08-2021, 09:04 PM   #225
Skyman2112
Skyman2112's Avatar
Drives: 2016 2SS blue velvet w/blk stripes
I already have an extra battery cable grounding the block to the chassis, but when i installed ceramic coated headers, i noticed sometimes if i have to stop and restart the car right away it barely starts, as in 9.58 volts according to my battery monitor. Should i get an extra heat shield?
Current mods. Rotofab CAI, Speed Engineering Long Tube Headers and plug wires w custom tune. Shock tower brace, ground effects, OEM brake air ducts and splash gaurd delete, 275/315 tires on 10 and 11 inch MRR wheels.
Skyman2112 is offline   Reply With Quote
Old 08-08-2021, 10:13 PM   #226
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Drives: 2020 2SS - A10, NPP, MRC, CAI
If you are still using your original battery it is time for a new battery.
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
2SS Capt is offline   Reply With Quote
Old 08-09-2021, 10:04 AM   #227
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Agreed - I'd start with a battery check. The engine to body ground helps to overcome the the heat soaked starter drag when there is a healthy battery. A weak battery can't overcome the heat soak even with a good ground.
Good luck and let us know how it turns out.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 08-09-2021, 12:10 PM   #228
Blobby
Drives: Former Owner '16 Camaro 2LT V6 conv
Are there traditional flooded batteries have a vent hose like AGM? As far as I can tell, AGM batts don’t have much of an advantage besides the safety aspect. The second perk I read they have is lower maintenance, but my flooded batts have always been, quite literally, zero maintenance.
Blobby is offline   Reply With Quote
Old 08-25-2021, 07:21 PM   #229
oOKhanhOo
Drives: 2018 SS 1LE
Just ordered from BATTERYCABLESUSA two 24" cables, I went with the 2/0AWG wire. What is the bolt size/thread?
Added an additional ground cable to help with the slow crank/hot engine issue...
Bought the cable from BatteryCablesUSA, 21" 0 Gauge (1/0), 3/8" connectors (M10): $12.81 + $3.97 shipping = $16.78 + $3.18 at Home Depot for a new bolt, nuts and washers... Total: $19.96 installed, took about 10 minutes...
oOKhanhOo is offline   Reply With Quote
Old 08-25-2021, 07:29 PM   #230
2SS Capt
2SS Capt's Avatar
See this post: https://www.camaro6.com/forums/showp...&postcount=124
Old 08-31-2021, 10:09 PM   #231
oOKhanhOo
Drives: 2018 SS 1LE
Update: I wired the wired it to the negative post in the engine bay and onto the engine. It did NOT fix my problem (slow crank/no crank/single click from starter solenoid I believe) :(
Old 09-01-2021, 01:22 PM   #232
SSDan
SSDan's Avatar
That's too bad! You may have more going on if you have a no crank situation and hear a click from the solenoid. I assume you have tested the battery/charging system and have good voltage.
Is the slow crank on a cold or a hot engine? Could you post a picture of where you connected the new ground cable if you used a different location than in this thread?
Most of us with the slow crank/hot engine have had 2016 SS models. I haven't read about any 2018 models with the issue until your post.
Good luck and keep us posted.
Old 09-05-2021, 02:34 PM   #233
oOKhanhOo
Drives: 2018 SS 1LE
No crank, single click I believe from the starter solenoid, when cold happened a couple days. That was the first time ever happening on a cold start.
Slow/no crank(single click) is happening on warm/hot start. I connected the new ground at the same location as the pic a few posts above. There are days where it starts up with no problem. But these symptoms has been more frequent as time goes by.
I need to load test the battery and connect the extra ground wire I bought in the trunk.
Old 09-05-2021, 03:10 PM   #234
2SS Capt
2SS Capt's Avatar
Sounds like your battery is shot...
Old 09-05-2021, 03:24 PM   #235
Blobby
Or wiggle the batt connections. There’s more than just a + & - back there to loosen or get cruddy.
Old 09-05-2021, 03:25 PM   #236
oOKhanhOo
Drives: 2018 SS 1LE
I hope that's the case! Much cheaper than starter replacement or any other causes.
Old 09-08-2021, 03:34 PM   #237
oOKhanhOo
Drives: 2018 SS 1LE
UPDATE: I went to Autozone and had them test my battery while it’s still in the car. It turns out to be a bad battery according to their device.
Old 09-08-2021, 04:56 PM   #238
SSDan
SSDan's Avatar
Here is hoping that new battery added to the ground cable(s) you've added puts your car right and your starting woes are behind you.
