Old 12-04-2023, 02:38 PM   #1
BRuiz922
Drives: 2016 Camaro 2SS
Rear shocks magnetic ride
Hi
A couple of weeks ago I noticed my suspension a bit rough mainly at the rear passenger side, too much bouncing, also some vibration. I change settings (T to Sport back and forth) but I don't notice any changes. Today I removed the rear passenger wheel looking for damaged trail/upper arms, rod, etc., but did not see any. There is some play with the tie rod. Two other things I saw are a missing bolt from the axle to the differential and "grease" like residue on the shocks, not leaking but like old grease. Could this be a sign of bad shock. I don't see any codes. Any thoughts?
BRuiz922 is offline   Reply With Quote
Old 12-21-2023, 07:02 PM   #2
NealC
Drives: Chevrolet Camaro SS
Take pictures if you don't mind, it would be helpful.
NealC is offline   Reply With Quote
Old 01-07-2024, 08:59 PM   #3
Vinny1le
Drives: 2022 1ss/1le
I have full mag ride set with camber plates for sale if you need it. has 8k miles and off a 22 ss/1le
id sell just the rears as well.
Vinny1le is offline   Reply With Quote
Old 01-07-2024, 10:06 PM   #4
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
Originally Posted by BRuiz922 View Post
Hi
Unfortunately, these are typical symptoms of MRC shock failure, and your car is a 2016, which places it right into the higher probability failure range (of 5 to 7 years).
Caveat: I'm not a mechanic and this isn't a proper diagnosis, you should go see a real mechanic or a service department to be certain, but I can say that several members have had proven MRC failures with similar symptoms after a similar amount of time (assuming your mileage is typical).
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
