Old 03-23-2021, 08:17 AM   #1
Osbornsm
Drives: 2018 SS 1LE
Arrow Brake Caliper Bolt p/n
Morning,
I cannot for the life of me verify the part number for the SS 1LE front brake caliper bolt.
This is the 6-piston Brembo setup.
Part number: __________ ??
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 03-24-2021, 02:16 AM   #2
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
front #11611085
rear#11570091
they are the same on all SS, SS/1LE, ZL1, ZL1/1LE
Old 03-24-2021, 06:56 AM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Here’s another option from Screaming Chicken.
There non-TTY bolt an it’s a complete set.
https://screamingchicken.com/2016-21...caliper-bolts/
Orange Krush II
Old 03-24-2021, 02:33 PM   #4
Osbornsm
Drives: 2018 SS 1LE
Originally Posted by JCunningham View Post
front #11611085
rear#11570091
No way really? I just ordered these: 11570092
I'm not sure what i just purchased then.
Old 03-24-2021, 10:41 PM   #5
JCunningham
Drives: 2017 2SS M6
same part just updated part number looks like. Few $ cheaper too.
Old 05-05-2021, 09:29 PM   #6
Shawnqa800720
Shawnqa800720's Avatar
Drives: 2018 1SS
Are the brake caliper bolts TTY on these cars?? I did not think those were.
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
Shawnqa800720 is offline   Reply With Quote
Old 05-09-2021, 05:01 PM   #7
Osbornsm
Drives: 2018 SS 1LE
Yes they are, as are alignment bolts too.
*sigh
Old 05-09-2021, 06:22 PM   #8
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Brake caliper bolts ARE NOT one time use TTY. They are TTA or TA. Which means torque + angle. They can be cleaned and reused with Loctite per the service manual. I've done it many times.
First Pass: 150 N-m (111 lb ft)
Final Pass: 15-30 degrees
carguy55 is offline   Reply With Quote
Old 05-09-2021, 08:49 PM   #9
Shawnqa800720
Drives: 2018 1SS
I love that I got two opposite answers to that question. I was at my local dealership this past weekend and they said that they reuse the caliper bolts as well. Not that that means much - not all dealership techs are superstars, but I would think they know the basics.
Old 05-10-2021, 09:22 AM   #10
carguy55
carguy55's Avatar
[QUOTE=Shawnqa800720;11007602]I love that I got two opposite answers to that question. I was at my local dealership this past weekend and they said that they reuse the caliper bolts as well. Not that that means much - not all dealership techs are superstars, but I would think they know the basics.[/QUOTE
Easy enough to access the service manuals and get your own answers like I do.
www.repairprocedures.com
Old 05-13-2021, 09:47 PM   #11
Shawnqa800720
Drives: 2018 1SS
[QUOTE=carguy55;11007774]
Would be great if it were free, but needing to subscribe seems crazy in this age of information. Are there free options - open access to service manuals? I thought that was passed as legislation, but maybe that was just local...
Old 05-14-2021, 10:05 AM   #12
carguy55
carguy55's Avatar
[QUOTE=Shawnqa800720;11010122]
I use the $15 for 1 day option and print to PDF everything I need
Old 05-14-2021, 03:46 PM   #13
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
I would think part of it is there's not a ton of TA spec'd fasteners out there. OE's usually go either straight torque or TTY, so people see that "+ x°" and the end of a spec and automatically assume it needs to be replaced. I bet other-party manuals may even get it wrong if they make that assumption, but Carguy is correct. Per GM's service manual brake caliper bolts do NOT need to be replaced, but the suspension alignment ones do after being tightened 2-3 times.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 03-02-2024, 05:50 PM   #14
Texan4iu
BLEW BIU
Texan4iu's Avatar
Drives: 2018 2SS 1LE Hyper Blue
front #11611085
rear#11570091
Funny thing about that part number for the front. It's a bit shorter and the head of it is a different size than my stock one. So I'm going to just use my stock with some loctite.
Texan4iu is offline   Reply With Quote
