03-28-2019, 01:36 AM | #1 |
Drives: 2019 Camaro SS 1LE Join Date: Mar 2019
Looking for a bit of help regarding this indoor ambient lighting
Hey guys, I'm getting this ambient lighting kit for the footwells and I wanted to hook it up via fuse box. On my 2019 ss, the only fuse boxes are under the hood and in the trunk. It would be amazing if there was one under the steering wheel like most cars do. There is this thing under the steering wheel that apparently I might be able to use to hook up the lighting kit to. I'm going to share a picture and a link... Any help would be greatly appreciated.
This is the ambient lighting kit: https://www.amazon.com/dp/B00OU5LOT2..._GOWMCb21K39GD Here is the thing under the steering wheel that I'll hopefully be able to use but don't know how to go about it: https://imgur.com/gallery/ArJo4Fl Thank youuuu! |
03-28-2019, 03:44 AM | #2 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
That would be the body control module (BCM) and I wouldn't screw with it, most voltages found there are not going to be 12v and if you do it won't have the current to run anything. Your best bet is to source power from the engine bay fuse box with an Add-A-Fuse tap (Micro2), if you deleted your sound tube that is an easy path.
https://www.amazon.com/gp/product/B0...HGP69UFE&psc=1 |
03-28-2019, 08:54 AM | #3 | |
03-28-2019, 04:38 PM | #4 |
Even if I didn't remove the sound tube I would still pass the wire through the tube/cover (drill/punch) it's the easiest way through and the sound tube only transmits vibrations anyway. Crap picture but its the black rubber nipple/cap under the driver's side strut brace, the nipple I added to fill in the hole left after removing the sound tube plate. I used a leather punch to make a small hole in the cap for the wire.
03-28-2019, 05:24 PM | #5 |
Drives: 2016 Camaro 1SS Join Date: Jun 2018
Looking at this install of curb alert:
https://www.camaro6.com/forums/showthread.php?t=435979 You can just pass the wire from the engine into the cabin easily through the door. |
03-28-2019, 06:21 PM | #6 | |
03-28-2019, 06:22 PM | #7 | |
