04-15-2020, 01:22 PM | #1 |
Instagram- _2sslow_
Drives: 2016 Camaro 2SS Join Date: Dec 2015
A8 transmission fluid change
I was looking into changing my automatic transmission fluid again because it has started to shudder again and I recently did the fluid change at the dealer under warranty in June 2019. I was wondering if anyone has used Royal Purple Max ATF Dextron
Instagram- _2sslow_
2011 Camaro LT RS (Sold) 2011 Range Rover Sport HSE (Sold) 2016 Camaro 2SS NPP, TSP headers & Xpipe, Skid e85, CAI Intake, MSD IM, 95m TB, BigPowerRacing Tune, H&R Lowering springs, BMR sway bars |
04-15-2020, 01:41 PM | #2 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
So you had the latest fluid and flush procedure done, and it's now shuddering again?
04-15-2020, 02:14 PM | #3 |
Instagram- _2sslow_
Yes it is so I wanna try something other than Mobil 1 now
Instagram- _2sslow_
04-15-2020, 05:25 PM | #4 |
If the latest Mobil1 LV fluid (19417577) didn't help, chances are you need a new torque converter and not yet another different fluid.
04-15-2020, 06:24 PM | #5 |
Instagram- _2sslow_
I wanna try one more fluid swap but different brand and if it doesn’t work then last resort is gunna be torque converter
Instagram- _2sslow_
04-15-2020, 10:46 PM | #6 |
Long hauler
04-16-2020, 12:07 AM | #7 |
Instagram- _2sslow_
No warranty’s been up for the last 6 months unfortunately but even when I was dealing with the issue then they made it clear they weren’t gunna replace that.
Instagram- _2sslow_
04-16-2020, 07:46 AM | #8 | |
The revised OEM TC costs about $3-400, which isn't horrendous (although at this point you may even want to go aftermarket, say, Circle D), the real issue is labor, not sure you want to support this seemingly unhelpful dealership.
04-17-2020, 08:49 PM | #9 |
Instagram- _2sslow_
Bump
Instagram- _2sslow_
