Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic modifications (exterior and interior)
AWE Tuning
Old 11-20-2017, 08:24 PM   #1
killa22
Drives: 2017 1SS/1LE
Replacing Diffuser (is rear bumper removal required)
Question -- would replacement of the rear diffuser/lower valence require the removal of the rear bumper?
or can it be swapped while the rear bumper is on the car?
killa22 is offline   Reply With Quote
Old 11-20-2017, 09:18 PM   #2
HyperBlue16
HyperBlue16's Avatar
Drives: 2016 Camaro RS
It is partly attached to the plastic piece(between bumper cover & aluminium bumper) under the bumper with clips you cant get to while on the car.
HyperBlue16 is offline   Reply With Quote
Old 11-20-2017, 09:42 PM   #3
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
http://www.camaro6.com/forums/showthread.php?t=490528
1hprush is offline   Reply With Quote
Old 11-21-2017, 02:30 PM   #4
killa22
Originally Posted by 1hprush View Post
Thanks for sharing that -- great video. Looks like taking the tail-lights off as well would be the more thorough approach, although it does seem doable with leaving them in place as well.
Old 11-21-2017, 02:48 PM   #5
Eos
Eos's Avatar
Drives: Camaro Coupé 2.0T AT8 (EU version)
Hi Killa22!,
as I had written on my thread.. here is my suggestion: go, take your time and remove the bumper if you want a professional final result.
See my old reply, explaining why:
If you want a professional result, it is mandatory. The diffuser has some metal clips (two or three, as I remember) that are positioned just in the center of the part. If you don't pull the whole bumper, the risk of damages is quite high. Indeed, the final finish of the paint on the recesses and corners where the two parts join can't be perfectly painted if the diffuser is not taken apart from the main bumper.
See you!!,
Eos
PS: Please, post some BEFORE/AFTER pics of your car!
Eos is offline   Reply With Quote
Old 11-23-2017, 02:32 AM   #6
killa22
Originally Posted by Eos View Post
Hi Killa22!,
See you!!,
Eos
Thanks Eos -- will get around to doing it sometime this weekend. Throwing on a ZL1 Diffuser on my 1LE, sprayed down a satin clear over a coat of black to match the splitter & ZL1 sideskirts. Will get it on once it cures.
Will get some pics up once its done.
