Vararam
Old 12-15-2022, 12:47 AM   #1
FastMatt12
Drives: Camaro SS
Magi 2300 Dyno
I think I am reaching the end of the power I can make with the Jackshaft 2300, at least on pump/meth. 733 RWHP / 679 rwtq ... Self tuned, I'm running 18deg of timing up to peek TQ then 19 deg after peek TQ to redline
2010 SS Stick shift
SBE LS3
Magi 2300
LPE 10 rib with 3% overdrive lower
2.70" 10 rib Griptech upper
1 to 1 rear Cog Drive
CWA 100 Intercooler pump
Ported Stock Heads
21C MC PD cam 224/239@0.050 .629 lift
2" Kooks headers
3" Kooks Exhaust
Solar Performance Ported LS3 TB
1050CC injectors
ZR1 pumps
Snow Stage 3 boost cooler Water/Meth Kit
Rotofab intake
ZL1 rear diff 3.73's, ZL1 drive shaft and Axles
I built this car with most of those parts back in 2010, added a few things like the 10 rib and cog rear drive as the years went on. It has held up like a champ, I always wanted to get 750 rw out of it but not sure it's going to get there with the 2300.... I think I am running out of parts to throw at it, any Suggestions?
I think the new 2650 kit is going to be the next step...
FastMatt12 is offline   Reply With Quote
Old 12-15-2022, 05:48 AM   #2
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Are you on E85?
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 12-15-2022, 06:36 AM   #3
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Originally Posted by Ashen 6.2 View Post
Are you on E85?
I think he's on 93 and Meth/Water.
FasNuf is online now   Reply With Quote
Old 12-15-2022, 09:40 AM   #4
eLeSthree
Drives: 2011 Camaro SS 6sp
What kind of boost pressure do you see?
What are the iat2 temps? and do you have enough fuel pressure to run some Ethanol?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 01-02-2023, 04:37 PM   #5
FastMatt12
Drives: Camaro SS
about 13-14psi, at the track the AIT's get into the 140's at the end of the 1/4. They don't sell E85 in my town, closest pump with it is 70 miles away each direction, so I would like to stay on Gas.
Old 01-04-2023, 07:17 AM   #6
cc-rider
Drives: 2010 Camaro SS
I think your self assessment is correct. You’re seeing the limits of what the Maggi can take. If you do some searches and reading here…that’s very typical number for where it runs out. You could have someone spec you a different cam that’s heavy on the top end curve and I bet you’d hit your 750 number. E85 would certainly get your number and then some with nothing more than a sensor and a bigger pump. Or…bigger blower as you suggested.
All that said, 733 WHP is a robust number! Nice build. I’m doing something similar right now.
cc-rider is offline   Reply With Quote
Old 02-15-2023, 09:34 PM   #7
Airborne1985
Drives: 10 Camaro SS & 16 z06 Corvette
Leftcoast32 makes a billet snout that will add 93 hp and 146 ft lbs of torque… also run a bigger throttle body
Airborne1985 is offline   Reply With Quote
Old 02-16-2023, 06:18 AM   #8
FasNuf
FasNuf's Avatar
Old 02-16-2023, 01:44 PM   #9
FasNuf
FasNuf's Avatar
Yea, E would be nice or even a tune for C16 would help, but there's the availability thing and cost. I haul 2 drums 60 miles south and fill them up on E and keep it in the shop. It's worth the drive for me considering even an E50 mix in my tank does wonders on power. The biggest block for you with E is probably fuel delivery with the ID1050's. Not sure what DC you're at now.
Old 02-17-2023, 06:07 PM   #10
Airborne1985
Originally Posted by FasNuf View Post
Slownuf relax you don’t know everything … https://youtu.be/jsisVu8bbso
Old 02-17-2023, 06:16 PM   #11
Airborne1985
2010 SS Stick shift
SBE LS3
Magi 2300
Ported Stock Heads
2" Kooks headers
3" Kooks Exhaust
1050CC injectors
ZR1 pumps
Rotofab intake
Here is the leftcoast32 snout
Old 02-17-2023, 06:32 PM   #12
FasNuf
FasNuf's Avatar
Sorry still calling BS. No way a ported snout and bigger TB gained 94hp, not on this planet anyways. Post all the pics you want. Oh, and it looks like you've made a whole 3 posts here so you have a lot of time to judge me on what I know.
Old 02-17-2023, 06:58 PM   #13
Airborne1985
Slow down pal; I been on this forum since 2010… loss my old account… in what context are you using the word judge? your acting like my ex wife ???
Old 02-17-2023, 08:47 PM   #14
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Ouch x10! lol. No skin in the game, just learning here but that one made me laugh. Those witches I tell ya.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
