AWE Tuning
Old 05-02-2019, 09:41 AM   #1
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
Lowering our Camaro's
So I recently upgraded my suspension with BMR components front and rear. Also done the Eibach pro springs at the same time. I had Eibach springs on my 5th Gen and worked and looked just fine but for some reason after timing my bushings and torquing the pivot bolts with the suspension loaded my front looks right but my rear looks a lot lower and the tires are tucked. So I have a reverse rack look. Don't like it. I have looked at pictures of several different ones with Eibach pro lowering springs some look like mine and some have a small gap front and rear. Will the front lower more with miles when it settles? Any thoughts and help would be great. Thanks
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
Old 05-07-2019, 12:37 PM   #2
L8Apex
Drives: 2016 2SS
I did the Eibach kit and got the same bit of a reverse rake look, however your rear is little lower than mine though, but the rest of my suspension is stock. What did you swap out with the BMR suspension, just anti-sway bars?
L8Apex is offline   Reply With Quote
Old 05-07-2019, 03:31 PM   #3
Hyper1SS
Hyper1SS's Avatar
I have the BMR front and rear sway bar with adjustable end links, all rear arms and adjustable toe rods, tunnel brace.
Order ID: TDHQMS
Old 05-08-2019, 08:58 PM   #4
Jsreo
Drives: 2017 2SS Manual
I agree, the back is a tad too low for my taste as well. The below link is another car on same spring with the same issue, I am looking at lowering my 2018 SS but I guess Eibach pro springs are not for me
https://www.camaro6.com/forums/showthread.php?t=552740
Jsreo is offline   Reply With Quote
Old 05-09-2019, 04:56 AM   #5
Hyper1SS
Hyper1SS's Avatar
Like most things every car is not the same and there are going to be + and - to everything. Eibach said they have several other options and can send me a rear spring to raise the rear about a 1/4 of a inch. I still have not had time to play around with the alignment anymore to see if I can adjust it where it sits a little higher. Time will tell and if I decide I don't like them I will find a different route or go back to stock.
Order ID: TDHQMS
Old 05-09-2019, 12:02 PM   #6
Jsreo
You car still looks 10x better than mine at the stock ride height & would be perfect IMO if you could raise the rear .25 to .5 "
Old 05-09-2019, 03:26 PM   #7
Hyper1SS
Hyper1SS's Avatar
Thank you! That's is what I was thinking at least a .25 of a inch.
Order ID: TDHQMS
Old 05-11-2019, 06:30 PM   #8
Hyper1SS
Hyper1SS's Avatar
So after talking to Eibach and others after research I decided to put the Camaro up on ramps to look things over. So with the suspension loaded I adjusted each connection one at a time and come to find out the inner cradle alignment bolt was rotated 180° the wrong way. Also the new BMR tow rods needed adjusted. Now it looks and sits like it is supposed to. Glad it all worked out and I did not have to uninstall them to go back to factory.
Order ID: TDHQMS
Old 05-11-2019, 06:51 PM   #9
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
Looks good! Which alignment cradle bolts do you speak of?
I want to lower mine so bad but I still need some track performance for those 60' times.
Boost, Boost & More Boost
Instagram = BoostedSS
SC88 is offline   Reply With Quote
Old 05-11-2019, 07:28 PM   #10
Hyper1SS
Hyper1SS's Avatar
Bottom left on the cradle
Order ID: TDHQMS
Old 05-11-2019, 07:43 PM   #11
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
Ahh ok Thanks for the picture. Now you have me wondering lol
1. How much ground clearance is left for the exhaust and Does the upward pitch of those arms effect handling and traction while driving down the road.
Old 05-11-2019, 07:56 PM   #12
Hyper1SS
Hyper1SS's Avatar
You are welcome. I have a aftermarket cat back exhaust and I have not measured clearance yet. Everything is aligned properly now and the ride and handling feels like OEM.
Order ID: TDHQMS
