Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 11-01-2020, 10:50 PM   #29
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
Originally Posted by James Montigny View Post
How the heck are you guys reaching up and unplugging this? Maybe I need to bribe a child with small arms to do this for me.
I couldn't, and eventually removed the front bumper to make room for a proper installation with my big hands.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 04-16-2021, 05:20 PM   #30
SinSStrNJ
Drives: Chevy Camaro 2SS
Completed!
Hi guys! I literally JUST finished my illuminated black bowtie. Thanks for everyone's help, posts, & pics. I could not have done it without that!
Only had a couple issues...
- The bending of the latch was a little nerve-wracking (I could just visualizing it snapping off).
- Getting the old bowtie to "unsnap" wasn't happening, so I ground the back of the clips off with a dremel to get them to release.
- Drilling the hole with the dremel wasn't as scary as the latch issue (above).
- Getting to the connections for the DRL was nuts. Took off more than a little skin, but eventually got it. (Note to others: Practice clipping and unclipping with the new harness connections. It helps to know the routine, as you'll be disconnecting the DRL blindly.)
That's again for such great info.
It looks amazing!
SinSStrNJ is offline   Reply With Quote
Old 04-16-2021, 06:25 PM   #31
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
I saw someone say that the dealer took the air box out and went and did it from there. They also used the drivers side connection instead of the passenger side the factory instructions say to use.
2004YZFR1 is offline   Reply With Quote
Old 04-17-2021, 01:09 AM   #32
SinSStrNJ
Might be easier. There's less crap in the way over there.
Old 05-06-2021, 09:49 AM   #33
monrroy0
Drives: 2017 Cmaro rs
Has anyone's car started making weird noises after they install the illuminated bowtie,
or is it just me?
monrroy0 is offline   Reply With Quote
Old 05-06-2021, 03:30 PM   #34
arpad_m
arpad_m's Avatar
or is it just me?
What weird noises? Coil whine, some kind of "electric hum", or...?
These are LEDs and not supposed to make any noise, the harness has no components on it that could emit noise either, are you sure this isn't something else you have just begun noticing? For example, HID headlights do whine quite audibly, which is normal.
735 rwhp | 665 rwtq
Old 05-12-2021, 06:00 AM   #35
Drew145022
Drives: 2017 Camaro 2SS Vert
Anyone know where to get the clip for the back of the bow tie? I have found a few without the harness but I can’t find a replacement clip for it I can make a harness if I can find it.
Drew145022 is offline   Reply With Quote
