05-11-2020, 07:55 PM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2019
Getting into Vehicle Options after Stereo Swap 2010 Camaro SS
I have a 2010 Camaro SS. I have ordered a PAC Kit to swap the stereo. On the Stock Stereo, you can get into Vehicle Options. One example of things you can set is whether you unlock one door or two when you unlock the car with the Key Fob. There are many other things you can change. Is there any way to change or view any of that after the Aftermarket Stereo is installed?
06-18-2020, 12:16 PM | #2 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
I'm going to go out on a limb and say no as an aftermarket stereo does not connect to the BCM.
I'm surprised this issue doesn't come up more often with the number of people that switch to after market radios. Unless I'm missing something. |
06-18-2020, 03:11 PM | #3 | |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
But then again, I haven't changed any of the settings since the day I bought the car almost seven years ago. So if the kit couldn't do it, it wasn't a deal breaker.
06-19-2020, 07:29 AM | #4 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
should of bought a maestro idatalink cam1 kit and compatible head unit. look into returning ur pac unit.....if u can’t, don’t research the maestro cuz you’ll just be that much more disappointed.
06-23-2020, 10:13 PM | #5 |
Drives: 2011 Camaro SS Join Date: Nov 2017
PAC has a module that allows you to change the settings but you basically set it how you want and you’re stuck with those settings unless you reprogram the unit again. Honestly I haven’t had the need to change my settings in the two years I’ve had mine. Give the PAC people a call and they’ll explain it better than I just did.
The Maestro unit just doesn’t look right to me, especially with the exposed USB and other connections on the front. IMO, the PAC looks better integrated than the MyLink.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current Last edited by Cheap Guy; 06-24-2020 at 10:00 AM. |
06-23-2020, 10:38 PM | #6 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
set it how you want it then change the radio it will retain you settings. how often do you change them?
most people set it and forget it. |
07-22-2020, 09:22 PM | #7 |
Drives: 2011 Victory Red Ls Join Date: Dec 2013
Hey there I see you have the idatalink and I was wondering if you could post some pics of your set up? I'm currently looking for an aftermarket stereo so any guidance is much appreciated!
2011 LS A6
Brembo SS brake swap, eighbach lowering spring prokit 1.3" drop, K&N typhoon 69 series intake, mace ported throttle body, intake manifold spacer, long tube headers->no cats->stock ss exhaust |
07-23-2020, 08:22 AM | #8 |
Cam1 Color Off
I am in the process of sending my IDatalink back because the color is off, brown tint, does not match console.
