AWE Tuning
Old 10-24-2013, 09:08 AM   #1
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
If a c7 runs 11's stock what should the next camaro run?
So after seeing a bone stock auto c7 run 11.6's at 3400+lbs without driver what do you think the next camaro will run if it gets the same engine? Low 12's mid to high 12's being the norm?
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 10-24-2013, 10:27 AM   #2
87GNX
87GNX's Avatar
Drives: Alot
Mid 12's
87GNX is offline   Reply With Quote
Old 10-24-2013, 10:38 AM   #3
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Where did you see a stock one go 11.60's? I find that hard to believe. The best times have been mid to low 12's I have seen. Unless this guy got a KILLER 60ft at the perfect temps I don't see that possible.
newagemuscle is offline   Reply With Quote
Old 10-24-2013, 10:45 AM   #4
newagemuscle
Philippians 4:13
Think I found it.
http://forums.corvetteforum.com/c7-t...7-atco-nj.html
That's crazy...
Old 10-24-2013, 03:38 PM   #5
KMPrenger
KMPrenger's Avatar
Holy CRAP.
I've only seen two other owner passes, and those were mid to low-mid 12s but I believe they were manual cars and not automatics.
The link says it was done on stock tires as well...that almost seems too good to be true.
I would have bet money the car would be able to hit a 12 flat but I never expected THAT.
If thats the case, and the 6th gen Camaro uses the same engine with the same power output and if it weighs a good 2 or 3 hundred lbs less I don't see at all why it couldn't run low to mid 12s stock.
Still sounds crazy.
Old 10-24-2013, 04:22 PM   #6
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
WOW!
That's amazing.
BaylorCamaro is offline   Reply With Quote
Old 10-24-2013, 05:27 PM   #7
NASTY99Z28
He posted his slips on tech and he's pulling 1.73-1.76 60's!!!!! BONE STOCK EVERYTING.
Old 10-24-2013, 05:35 PM   #8
Low 12's
Old 10-24-2013, 09:18 PM   #9
shine2013
shine2013's Avatar
Drives: 2008 Mustang GT
Mid 12s, but if the Mustang loses 400lbs like it's rumored I think the Camaro is going to hit low 12s to keep up.
shine2013 is offline   Reply With Quote
Old 10-24-2013, 09:49 PM   #10
KMPrenger
KMPrenger's Avatar
I seriously doubt the Mustang is going to lose that much weight. The new car apparently rides on the same 107 wheelbase as the current car, but the changes in sheetmetal and what not make the smaller and probably help to shave some weight a long with advancements in the chassis. The independent suspension likely doesn't help in shaving weight either.
In the end, if the V8 Mustang weighs much under 3,400 if it even gets under that I'll be pretty impressed. It would have to weigh around 3,200 lbs if it lost 400 lbs.
Old 10-25-2013, 08:29 AM   #11
newmoon
newmoon's Avatar
Drives: 2019 GT350
I knew the low 12s were going to fall once somebody got an automatic on the track in good weather. Beautiful times...., Also anyone doubting the 60' times remember we are talking an automatic car here 1.70s on stock rubber, should be possible.
2019 GT350 RR
2013 Boss Mustang
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
Old 10-25-2013, 11:11 AM   #12
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Just because a C7 has run mid 11s, that should in no way indicate what a 6th gen Camaro 'should' do. When I see the word 'should' I think of normal, average times. Not hero runs.
If you consider the C7 to be a mid 11 second car, then the 5th gen is mid 12s. The added power & reduced weight should shave a few tenths off the next gen, which would put it in the low 12s.
And moved to the 6th Gen sub-forum
Odds are, if the Mustang looses 400 lbs it will not be between comparable powertrains. Throw a NA 4 cylinder in as the base engine & you save a whole bunch of weight vs a V6.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-25-2013, 11:20 AM   #13
KMPrenger
KMPrenger's Avatar
Agree.
If the base car weighs 3,200 lbs (still really good) you still have to take into consideration that the GT will likely weigh a couple hundred lbs more...int he 3,400 ish range. I still think when you compare similar equipped GT models from the current 13/14 model to the new 15, I'm going to guess somewhere between 150 - 250lbs lost.
Old 10-25-2013, 11:28 AM   #14
Juiced1
Drives: 2012 2SS CAMARO 45th
There have been plenty of bone stock LS3 Vettes hitting high 11s so this doesn't surprise me much (ideal temps and track). The next gen Camaro with the same engine should be pretty fast. If they end up on the ATS platform and can keep the weight under 3500 it should be in the mid 12s all day with some guys diving into the low 12s and I'm sure there will be a freak or two to pop off an 11.99.
